Results 1 to 4 of 4
Thread: hub/carputer distance
    Newbie blackmamba's Avatar
    Mar 2006
    Canadia
    Hello All,
    I am just getting started in mocking up my carputer and I was wondering if anyone could tell me something about Firewire/USB hubs.
    I am plannig on having my system (laptop) in the boot of my car and running a firewire cable(6 pin) up to the front where I would connect my touch screen / ipod / dvd-drive to a hub. My question is: Is this too far to run a firewire cable (about 15' of cable) and will the hub be able to draw the necessary power or should I get a powered hub?
    thanks for any info you can give.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    if powering the DVD drive and/or charging your ipod then get a powered hub.
    max usb length is 5m. dunno about firewire. it!
    Mar 2006
    Canadia
    thanks for the response
    1. It seems max firewire length is 4.5m (might be enough)
    2. I will be powering my dvd-drive and the occasional ipod so I guess I will be going with a powered hub.
    Mar 2004
    Bristol
    you can power the hub off your carPC psu for best results.
  1. minimum distance between power & rca wires
    By michaelrj9 in forum Car Audio
    Last Post: 08-30-2005, 02:02 PM
  2. Replies: 1
    Last Post: 07-01-2005, 05:00 AM
  3. Distance (Rangefinder) Sensor?
    By Banderon in forum General Hardware Discussion
    Last Post: 06-29-2005, 10:03 AM
  4. Voice Doesn't Always Announce Distance
    By skeeter007 in forum Map Monkey
    Last Post: 12-22-2004, 04:47 PM
  5. Distance, Speed Logging Utility?
    By Bigtom2000 in forum GPS
    Last Post: 06-18-2004, 06:42 PM
