you could just partition the 300gig in to one little partition(10 or 20gig) for OS/software and whatever is left into a big media partition
Hello, my system i decided to go with a 300gig 3.5" 7500rpm hd. I want to put a hell of a lot of media in there. one of my friends told me that i was going to be using one hard drive, that there might be a slowing of response. since its trying to access all the media and me running the frontend and so on, he recommended me running 2 HDs, 1 for the software and one for the media. Is this correct? does anybody have any insight on this. I have an old 40gig 2.5 laptop hard drive. i was planning on using the 40 gig for the OS and daisy chain it to the 300 gig. I was going to be using
and i want to use this
How can i use this adapter with this ide cable with they are both females. Is there any ide flat cable gender changer? thanks
I have taken it a step further and partitioned my media drive into about 18 seperate logical drives. With somewhere near 40k mp3s it was taking forever for indexing to complete and my libraries to load. Having all the media organized on seperate logical partitions has helped tremedssly.
Keep in mind that for indexing & stuff that'll help. For physically accessing the data, partitioning won't be enough. No matter how many partitions you have on the drive, it still only has one read/write head.
I think the best way to go is a 20-40 gb for your OS, and applications, and then a removable HD for Media, which you can easily take into the house.
That being said, I have a 120gig drive with 20g for apps and OS and 100 gig for media, and no complaints.
Is this where the witty comment goes?97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
Originally Posted by GreenBeast
That won't do it.
When it comes to hard drives it helps to think about how they work. The platters inside are spinning and the head has to move in towards the center of the platter, and back out, in order to locate the head over the data (cylinder) that it needs to read.
The speed increase from having multiple drives is because you have multiple heads seeking data and simultaneous data transfer occuring between the two drives. This eliminates some contention and thrashing.
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
The best way to speed up a set of two hard drives is to use a Raid0 array. This is striping. For this to work you would need to identical hard drives size wise. What happens is data is split between each drive like stripes on a shirt, equally divided, one here one there.
Raid0 allows for faster file access because two drives are pulling the data. The down side? In a two drive system if either of these drives becomes corrupt you whole install is wasted.
In Raid0 you can add as many hard drives as your board can support. If you use three or more drives you can rebuild a lost/damaged drive off parity (spelling?).
3 x 80GB hard drives is 240GB of storage. 3x 40gb is 120GB.
And for the cable you're asking about, that is a IDE to laptop hard drive, if you use 3.5" hard drives you dont need it.
