Results 1 to 5 of 5
Thread: Splice into fuse box: '02 Camry
    Mar 2006
    I am new to this and need help. I have a Toyota Camry 2002 and am installing an access control device that needs 9 to 12 volts and 300 milli-amps, even when the car is off. I am mounting the device near the fuse box of my car and would like to splice into existing wiring for power.
    I have found the factory repair manuals (http://oregonstate.edu/~tongt/camry/index.html), but am having trouble making sense of them.
    Does anyone know of what wires I can/should attach to in a 2002 Toyota Camry that will provide always on power?
    Thank you!
    Joe
    Newbie husalah5150's Avatar
    Dec 2005
    I just got a 2003 camry so im not sure where constant 12v id but theres always one behind the radio and at the ignition. Just look up a car alarm install diagrams that tell u the colors for your 2002 camry
    May 2005
    Well, if you're installing something right near the fuse block, taking power from somewhere else (like the headunit) would probably be more of a pain then what it's worth.
    Looking at your fuse block:
    http://oregonstate.edu/~tongt/camry/68_Wiring.pdf
    on page 4, you can see the layout of all your fuses and what they're used for. The first thing to check for, would be if there is a place for a spare fuse. If not, it's possible to tap into an existing one. After you find a spare fuse/one that you can work with, check to see that the fuse still has power when the car is completly off. If yes, then use this. If not, then find one that does.
    Also, if you do find a place for a spare fuse, put in a 1 amp fuse, or something similar. If you have to tap into an existing fuse, try and use one that's small (like 5 amps, as opposed to 30)
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    Newbie klp45's Avatar
    Sep 2005
    Stop the guess work.
    BUY a multimeter! You'll be glad you did.
    '98 Acura TL 3.2 >Epia M10000 >512ram >200gb >XP pro>Lilli 619> Opus 120
    TESTING as of 6/22/08 - Intel D945GCLF, 2GB RAM, 80gb HDD, XP pro SP1, same Lilli & Opus 120
    Jan 2006
    buy a multimeter
    and
    www.toyotanation.com
    98 V6 Camry XLE
    Status-Everything is working again!
    No progress while I am in NYC
    Ze Worklog
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 11:01 AM
  2. Powering through Fuse box
    By Frogon in forum Newbie
    Last Post: 02-02-2006, 07:49 PM
  3. Linking fuse box to pc
    By richardneail in forum Input Devices
    Last Post: 09-27-2005, 05:14 PM
  4. Running power to fuse box from battery....
    By gambit32 in forum Power Supplies
    Last Post: 09-29-2004, 03:57 PM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
