Results 11 to 20 of 28
Thread: Rough draft: Equipment list, total n00b
  1. #11
    Sep 2005
    Cpu is on the mobo, no chance of that thing going anywhere. I'm sure there are tons of people who have absolutely no shock absorbing at all and things work fine.
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Eubey
    ok, so i am now thinking i will stick with the case, but add some shock absorbing springs below it, which will also create room for a fan below the case, which will also increase cooling (texas weather gets way hot)... does the ampie come in any other color other than blue or is blue it?
    i'm running my mobo behind a interior body pannel not in a case with only the CPU fan, and I've never run into any issues with heat. I'm in Texas as well, have had a carPC in for about 3 years.
    My mobo is also mounted directly to a piece of MDF without any shock absorbing, and have yet to have a single issue.
    you can see pics on how my computer is mounted in my sig, also, since you're in Texas, check out http://www.carpctexas.org
    Jan Bennett
  3. #13
    Mar 2006
    step ahead of ya man. already joined up... So heat isnt a big issue? thats a relief. does the hard drive not get banged up from speed bumps and stufF? I know laptops have extra protection built in, but texas roads are never kind, specially on my street
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    nope - mine hasn't had a single issue. I plan on defragging it again pretty soon, so I'll have a better idea of how it's faired over the past year and a half.
    Jan Bennett
  5. #15
    Elsewhere
    Dude, you're asking questions that have been answered or discussed or debated dozens of times over.
    Search the forums for HARD DRIVE SHOCK and you'll get lots of threads discussing this very topic.
    I have a regular 3.5" Maxtor 120GB HDD in my setup and I drive on Texas roads that are **** quality in a truck with stock suspension. It doesn't miss a beat.
    How about the Wiki?
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    man - this is precisely why I kept out of the n00b forums....lol
    Jan Bennett
  7. #17
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    My only concern would be the subs wiping the harddrive. My carputers never lasted more than a few days when I had them beside my sub. It never damaged the drive.. just files would disappear until windows wouldn't start anymore. I moved it into the interior of the car, and havent had a problem since.
  8. #18
    Mar 2006
    Subs=giant magnents... Harddirives = spinning disks with electrons oriented to represent 0's or 1's. Magnents <3 Electrons... So having a hdd next to a sub slowly(or quickly depending on the distance) corrupts your 0's and 1's...
  9. #19
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    The vibrations caused by the sub are also very very had to the hard drive. Think of a wheel spinning, everything is good when it is balanced. When you get a wheel off balanced it wobbles and goes crazy. A hard drive has the same concept, the disk head spins in the drive (5400 times a minute for a 5400RPM drive, 7200 times for a 7200RPM drive), think what type of destructions a sub can do to it.
    These should not be confused by the variations in road conditions. The road conditions have a far less impact than parking your drive in or right next to a sub
  10. #20
    Mar 2006
    so would the compartment between the drivers set and the passender seat be a better place to put it?
  1. Total Frikin n00b here
    By BMVEE in forum Car Audio
    Last Post: 03-13-2005, 11:14 PM
  2. Total N00B questions
    By MYNISMO in forum Newbie
    Last Post: 12-29-2004, 03:28 PM
