Results 1 to 8 of 8
Thread: How fast is VIA VIA EPIA M10000 Mini-ITX Mainboard [MP3CAR-0045]
    Newbie husalah5150's Avatar
    Dec 2005
    Ok i been reading around and someone said the the cpu is on the mother board already so how fast is a VIA VIA EPIA M10000 Mini-ITX Mainboard [MP3CAR-0045] and how come they dont say in the store? if anyone knows
    _
    Mar 2004
    Little Elm, Texas
    VIA chips aren't very fast at all, but in all reality, how much power do you REALLY need in a car?
    from what I understand the VIA chips are a little more than half of their equal speed in pentium...
    and IIRC, they list it at 1 GHz...and there are other places to look for specs than MP3car.com/store
    Jan Bennett
    Dec 2005
    I see. Im trynna fiqure out whats a good speed for using gps while listening to music and it not affect the gps screen. Also looking for it to load quick in winamp from track to track. Oh yea and movies (DVDs,Xvid,Divx and VCDs)
    thanks, quick reply
    Constant Bitrate icecore's Avatar
    Aug 2005
    Estero, FL
    Gooooood enough, it will work just fine with a M10000.
    Asus MicroATX with GeFore 6100, Mobile Sempron 3300+, 1Gig Ram, 320GB 3.5" 7200UPM HDD, M2-ATX, Gain/Xenarc 7"
    Fast IS my copilot
    _
    Mar 2004
    Little Elm, Texas
    i ran this board a while back as a first board. i was running gps, winamp, xm pcr, dvd, etc.
    could it have been faster?
    sure
    was it slow enough to bother me?
    not really
    Jan Bennett
    FLAC -zip-'s Avatar
    Ontario/Canada
    If you can afford it look into the SP 1300, will give you a little more horsepower for flash, voice recognition, better video decoder, faster memory
    Sound Stage
    Eclipse|MTX|Infinity
    Feb 2004
    North Aurora, IL
    if i were u, id get a athlon mobile... for slightly more power consumption they pack more bang for the buck.
    For a fraction of hte price u would pay for a mini-itx board you could get a lot better amd mobile athlon setup.
    this is comming from a person who used a MII12000 for a couple of years just because it was the popular thing to do at the time (mini-itx) and i regretted every moment of it. It got bogged down running video, and gps(igmod w/ iguidance) in the background. You would have to shut down the gps and then watch videos, which gets cumbersome at times
    the only reason to go for a mini-itx (imho) would be if you were had to do a very small install
    now that i ranted.. ill answer your question
    the M10000 is roughly about the same proccessing power as a normal 700-800 mhz processor. i read somewhere a while back while i was researching a few years ago that the equivalent via chipsets in the mini-itx were about 200-300mhz slower than the equivalent normal chips.
    I wish i knew how to do fiberglass work...
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    Quote Originally Posted by theheel
    The Turion Mobile chips (AMD 64 BIT Socket 754) use less power at only 35w. They pack more punch for the power draw and can handel anything you throw at them. Combo that with a Gigabyte GA-K8N51GMF Socket 754 NVIDIA GeForce 6100 Micro ATX AMD Motherboard and you'll have one excellent system.
  1. best mini itx board
    By 2nau-t in forum General Hardware Discussion
    Last Post: 09-08-2004, 11:05 PM
  2. Bargain!! Via Epia Nehemiah 1ghz Mini Itx Mainboard
    By dave0109 in forum Classified Archive
    Last Post: 05-26-2004, 07:40 AM
  3. Mini ITX MB? HELP
    By fondoo in forum General Hardware Discussion
    Last Post: 05-06-2004, 09:46 PM
  4. EPIA VIA M10000 Mini ITX in a 6x9 Speaker Box pic. 2 hour build time.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 02-13-2004, 01:24 PM
  5. VIA EPIA Mini ITX beeping problem
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 06-28-2002, 11:31 PM
