Results 1 to 8 of 8
Thread: running a LCD 17" screen in car
    Feb 2006
    Dallas,TX
    HI
    ive tried searching and ok
    I have a friend and he put like a 17" LCD monitor in his car and i think he powered it using a AC inverter but the only problem is that is brought in lots of noise into the system.
    so he took it out.
    My question is that is it bad to put a 17" LCD monitor in your car to use as your display?
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    Is it bad? Are you looking for moral guidance?
    A 17" brings complications, such as power, size, and placement, but if you can do it successfully then what could be bad about it? It's all about your personal requirements.
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    I'd assume that a 17" LCD would look good in a SUV/Truck, not in a compact 4-door sedan/wagon.
    Plus, it might be more challenging to find a touchscreen if you'd be going that route. If you do put a touchscreen there, tell your index finger to pack its bags, because it's going to do a lot of travelling.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Feb 2006
    Dallas,TX
    i am not looking to use the 17 inch for a touch screen.
    if i want a touch screen ill just get one of the 7 inch touch screens from MP3car.com
    thank you for your reply
    so basically your sayin its not bad to have it running through the AC inverter?
    Quote Originally Posted by RawsonDR
    Dec 2005
    Dayton, OH
    Quote Originally Posted by Raichu626
    I have a 15" screen which I plan on mounting in my car. When I plugged it into my inverter, I noticed wavy lines in the display. However, when I used my friend's inverter the display was perfect. If you can power the screen with a DC-DC power supply, it would probably be best. However, an inverter can work, it will just require some potential troubleshooting. I haven't messed with my inverter yet but I still feel I may be able to fix the noise through grounding, shielding, or simply getting a new inverter.
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    i got a 12 inch. think it works out perfect.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Mar 2006
    Quote Originally Posted by 84RegalRider
    What did you use to power it???
    May 2005
    I have a 14" screen in my truck (pics are in progress thread..link in sig)
    It works perfect, aside from the wavy lines going through it. The problem is that I'm using a modified sine wave inverter, if I were to get a pure sine wave inverter, I don't think I would get the lines. Either way, the lines really aren't bad, and don't bother me. But down the road, I might think about upgrading to a pure sine wave inverter or, if they eventually offer one big enough, a DC-DC power supply.
    To answer your question: there is nothing bad about putting a bigger screen in your vehicle.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
  1. Generic "Verge" Xbox Lcd is a PSOne screen!?!
    By Navinity in forum LCD/Display
    Last Post: 12-11-2005, 08:00 PM
  2. Faulty second hand LCD screen,, need help!
    By mongo_pete in forum LCD/Display
    Last Post: 06-22-2005, 06:37 PM
  3. Introduction and question about Car LCD
    By Data Android in forum LCD/Display
    Last Post: 12-08-2004, 03:05 PM
  4. Second LCD screen for my 3.5 year old son.
    By Nokia6600 in forum LCD/Display
    Last Post: 03-06-2004, 04:23 PM
