Results 1 to 5 of 5
Thread: Motherboard Comparo
    Low Bitrate SuprchargdMazda's Avatar
    Mar 2006
    Motherboard Comparo
    BIOSTAR GEFORCE 6100-M7 Micro ATX vs. MSI K8MM-V Socket 754 VIA K8M800 Micro ATX
    So the Biostar supposedly has great onboard video, but the MSI is a bit smaller at 9.6x7.6 vs. 9.6x9.6. The Biostar also has PCI-E but that doesnt matter because I wont be running a video card on it. Its only 8 bucks difference so price isnt a factor. Size is, but Im not sure if I really need those 2 inches or not. What do you guys think about the Biostars onboard video vs. the MSI's? If its that much better than Ill go with the Biostar..
    Oct 2005
    Hou. TX
    Well, I looked at both and couldn't see were either supported the "CnQ" feature or S3 suspend. Those are 2 cool features I would look for.
    The manual says the GEFORCE 6100-M7 doesn't support WN98SE or ME. So I guess you'll need to use 2000 or XP. Don't know if that is a issue for you or not. It does have a fan speed controller and Hardware Monitor. I couldn't find much on the MSI.
    I would email both companies and ask about S3 suspend (if you want fast turn on's), CnQ (if you want to have the CPU run cooler and quiter) and fan control. I think those features are really good for a CarPC.
    I would start reading the Newegg reviews and see if there are any issues you should be aware of. Make sure they have the feature you are looking for.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    I'm using an older Biostar with the GeForce 4 and couldn't be happier. I don't have S3 and probably wouldn't use it due to battery drain. Hibernation works great for me and my PCs that do have S3 give me nightmares (although I think its mainly media center's fault).
    I have a MSI with ATi graphics and it's pretty damn solid. No problems with it at all. I know you said you were going with an external video card, so it may not be an issue but I've read the unichrome chip can be a ***** to get working with the 800x480 res. Why use an external card? The GeForce 6100 on the Biostar has a pretty good reputation, more than adequate for carpc use. Unless you're gaming or something.
    tbird2340 has the biostar motherboard in his sig. Might want to hit him up for some info.
    Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
    Mar 2006
    Quote Originally Posted by SuprchargdMazda
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If you are going to use Onboard video, go with biostar.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Perfect uATX Motherboard for a CARPC
    By checksum in forum General Hardware Discussion
    Last Post: 03-26-2006, 07:00 PM
  2. Still Can't Get New Motherboard To Power Up
    By james33440 in forum General Hardware Discussion
    Last Post: 10-22-2005, 12:02 AM
  3. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 12:00 AM
  4. Which Motherboard to Choose
    Last Post: 06-07-2005, 10:35 PM
  5. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 04:38 PM
