BWAHAHA....don't kid yourself. Blose blows. anyway, with that being said, you should know that the bose system is easily removable in that you can buy a pigtail that will join the harnii that go in and out of the amp so you can install an aftermarket deck. In previous years the bose systems used 3ohm speakers making them incompatible with most aftermarket stuff. But recently they have switched to 4ohm/8ohm setups meaning you can use them with standard amps. my 972.2cl had 4ohm speakers in it and i used them for a while before upgrading. If you are planning to install a carputer or a halfway decent car stereo i would highly recommend ditching the bose setup alltogether. Just make sure you hang on to all the parts so you can reinstall it when you sell the car.Originally Posted by gswans5
LinkBack URL
About LinkBacks
