Results 1 to 6 of 6
Thread: question!!!
    Apr 2006
    question!!!
    This had probably been asked over and over again but I can't seem to find anything. Can you get rid of the hu all in one...and not use a hu at all? maybe maybe not? and if I can't can I use my stock monsoon amp/hu in my 99 camaro?
    Mar 2006
    Colorado, but Canadian!
    Angry You really need to search...
    This question has been answered a thousand times and is still one of the major questions in the n00b section. Yes you can get rid of you HU all together, or you can keep it and use the aux inputs for the computer. Having a HU is beneficial if you like radio (not satellite), because pc radio is complete crap compared to even a cheap HU. Also HU boot up is 1-2secs and a PC is like 20-40secs depending on config. If you are taking a trip like 1 minute down the road, not even worth it to turn on the PC. If you keep a stock HU, then you will have either no display, or a display that is goosenecked making it really obvious. The stock amp and everything will work. If you go all PC, then you most definately need an amp.
    Really dude, comon. Search. If you look for like 1 minute in the n00b section (even in the stickies) you will answer all these questions....
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    This doesn't even belong in the FAQ section.
    Link to answer:
    HOW TO: Get sound from PC to Car Stereo / Amp
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Well, you found the FAQ Emporium, but didn't see the post on how to do this. DJiK's link is the one you want. You should also search using terms "Monsoon".
    In addition, you will generate more looks and answers if you use a descriptive thread title. For example:
    "Is it possible to get rid of the Head Unit?"
    Want to:
    Low Bitrate I302K's Avatar
    Mar 2006
    NY
    I dont know much about the monsoon amp in the vw but the infiniti has boss and the way i riged it was. i took a rca cable with a head phone jack at one end and cut the rca leads off and splices them into the lines going to the amp left to left front to front and so on. use the opus remote cable and pluged that into the remote cable for the amp and it all work just fine and sound pretty good
    Jun 2004
    Rochester
    Here is a wiring diagram for your '99 Camaro.
    99CamaroMonsoonRadio.pdf
    I didn't see a remote turn-on wire that went from the head unit to the monsoon amplifier so I think you might need to use a solution like the VW folks (turn on signal over one of the audio wires). Take a look at the VW Monsoon FAQ:
    http://mp3car.com/vbulletin/showthread.php?t=63879
    Hope this helps.
  1. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 11:07 AM
  2. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  3. Complete Newbie Question.
    By DomesticImport in forum Newbie
    Last Post: 07-07-2005, 07:24 PM
  4. little question ive pondered..
    By John Crowe in forum Newbie
    Last Post: 04-06-2005, 05:09 AM
  5. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
