Results 1 to 8 of 8
Thread: Power Supply for laptop
    May 2005
    Im going with a ibm thinkpad with a docking station to run my carputer. I looked up power supplies/starup controllers but theyre for pc's or are they compatatble with laptop. basically how would i be able to have the laptop start up and shut down when i start/turn off car w/o loss of info
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    If you read the n00b FAQ's you'll see why nobody is answering this for you.
    Attention Newbies! A FAQ to the FAQs
    ~Jimmy
    May 2005
    ok.... took me a hour to read the faqs. I decided to go with the inverter for the laptop. Im wondering if the crank would be a issue if the battery is in the laptop. Basically the inverter would be used to recharge the battery(or i can charge it in the house) if it goes dead. Or i can use the inverter for other things if it arises.
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    That's a good thing to wonder.
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by TheLlama
    The laptops normally will automatically switch to battery when A/C power it cut off so cranking should not be an issue...
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    May 2005
    yep... thanks alot, ill juss figure out how to make a power on button so i dont have to go under the seat to turn the laptop on. FAQ is a good thing lol
    Elsewhere
    It's only a good thing when it's utilized.
    How about the Wiki?
    May 2005
    Ok now a more specific question. the laptop im picking up has a built-in 16-bit stereo PCI audio supports Sound Blaster audio applications. Would this make the music sound crappy or will i have to upgrade the soundcard? The video has Accelerated Graphics Port (AGP) support with video acceleration and 2.5 MB of video RAM. Its a older laptop but for 200 buks with docking and port replicator why not?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. REVIEW::220 Watt DC-DC Power Supply: DSATX
    By seabeggar69 in forum Power Supplies
    Last Post: 03-20-2006, 05:53 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
