I'd make sure nothing is plugged in (i.e usb devices....even mice and keyboards, use ps2 at first).
Alright, first of all here is my computer:
Asus A7N8X
AMD Athlon Mobile 2200
60GB WD 2.5''
Kingston 512MB
MY problem is at the time I install the windows XP, and everything was OK, like the Hard drive formatted, then the hard drive copy files from the CD so after they need to restart to continue installing, then when the windows load up, it just stop right there and forever, and I try to turn off and on and computer again, still the same problem.
So I decided to take out a hard drive from my laptop (Hitachi 60GD) and tried to install it, and still got the same problem at windows XP Loading. By the way, I took that Western Digital 60GB to install to my laptop and everything work fine, I don't know what wrong with my computer.
So can you guys please check if my mobother support for that CPU, thanks
Asus A7N8X
CPU Socket A for AMD Athlon™ XP/Athlon™ / Duron™
Thoroughbred/ Barton Core Support
Chipset North Bridge: NVIDIA® nForce2 SPP(Ultra 400)
South Bridge: NVIDIA® nForce2 MCP
Front Side Bus 400* / 333 / 266 / 200 MHz
( * PCB 1.06 or earlier version need BIOS update )
Memory Dual-Channel DDR 400
3 x 184-pin DIMM Sockets
Max. 3 GB unbuffered PC3200/PC2700/PC2100/PC1600 non-ECC DDR RAM Memory (Twinbank)
Expansion Slots 1 x AGP Pro/8X (1.5V only)
5 x PCI
IDE 2 x UltraDMA 133/100/66/33
Audio Realtek® ALC650 6CH w/built in HP amplifier
LAN 1 Ports
MCP integrated NVIDIA® MAC + Realtek® 8201BL PHY
Special Features Power Loss Restart
Q-Fan Technology
STR (Suspend-to-RAM)
C.O.P. (CPU Overheating Protection)
CPU Throttle
Back Panel I/O Ports 1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O
4 x USB 2.0
Internal I/O Connectors 1 x USB 2.0 connector support additional 2 USB 2.0 ports
CPU/Power/Chassis FAN connectors
Game Connector
20 pin ATX power connector
IDE LED connector, power LED connector
WOR, WOL, Chassis Intrusion, SM Bus, SIR
Headphone (optional)
Front MIC
CD/AUX/Modem audio in
Front Panel Audio connector (optional)
BIOS 2Mb Flash ROM, Award BIOS, TCAV, PnP, DMI2.0, DMI, Green
Industrial Standard PCI 2.2, USB 2.0
Manageability DMI 2.0, WOR, WOL, Chassis Intrusion, SM Bus
PC Components:
My work log
If this is the first time this system has been together, I'd run a burn in utility.
I don't think you would even be able to run the windows installation utility if the cpu and mobo didn't match. Are you installing windows on the same system you're trying to run it? You can't do a windows install on one setup then take the hard drive from that setup and put it in another box and expect it to work.Originally Posted by shinjetko
GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
Now with pictures!
what is your drive boot sequence set up as in the bios?
, I did plugged it the keyboard, cuz I need it for installation. thanks like pressing enter or something else,Originally Posted by Peoples
by the way, here is the pix i got stuck at......
I am using regular power supply, 350WOriginally Posted by DarquePervert
I set first boot is cd-room, cuz I need to run the cd-room to install windows XP (windows XP CD is in the cd-room)Originally Posted by v8 scimitar
Cd rom can be second because your hard drive is blank so it wont boot from it, It will go to second boot and get the boot file from the CD. It should be ok but it might be trying to boot from the CD again and getting errors due to the half installed windows. If you re-boot do you get a message saying the last install failed?
