Results 1 to 10 of 12
Thread: Power sources for carpc M2-ATX
    Jan 2006
    Cyprus
    Car: BMW E46 coupe.
    All relevant parts have been collected:
    1. Xenarc 7"TSV
    2. VIA mini-ITX w 512RAM & 80GB 2.5"HDD
    3. M2 ATX PSU
    4. Case
    5. Extension cables
    6. Radio (used as an Amp and RCA Input from soundcard)
    7. BMW Climate control relocation part
    8. Steering wheel adaptor
    9. ISO to BMW plug converters
    10. Double din adaptor for the TFT (under construction)
    11. Lots of time
    One question only:
    Where do you get the power from for the M2 ATX? the TFT will be powered from the radio line, 7watt is not too much anyway - but what about the mobo?
    I'm planning to stick the mobo under driver's seat - to avoid running long extensions from the trunk.
    Will the power supply for the radio be enough to power the M2/mobo?
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Should be, but I'd run a seperate (fused) lead straight from the battery. For ground, just use the car...any metal part
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Jan 2006
    Cyprus
    Any ideas from where to get a good power line from a BMW E46?
    Jun 2004
    South-Central PA
    Not familiar with Beamers, but either come directly from the battery, or it should have a location for easy access (like if needing a jump start)
    Jul 2005
    AZ
    Quote Originally Posted by paris
    You might want to PM Hark. He's a master E46er. Post back to let us know what you come up with. I'm in the same boat...exact same boat.
    I just have clearance for the MB under the passenger seat of my e46. I selected this location because I think the trunk will get too hot here in AZ and I ddidn't want to make the long cable runs...
    Problem is, I might have to anyway to place the GPS and Sat Radio Equipment. I'm thinking the cable run should be down the passenger and rear door jam..but I'm not sure.
    Share your thoughts on all this in more detail and maybe we can sort it for both of us.
    Jan 2006
    Cyprus
    I believe the cigarette lighter line will be a good source for the motherboard.
    What I'm thinking is to take the cables from the Radio/Climate control part of the dash, pass them under gear knob cover, under handbrake cover and finally end up below the driver or passenger seat.
    For GPS:
    http://cgi.ebay.co.uk/USA-MADE-AyAy-...QQcmdZViewItem
    Jul 2005
    AZ
    For GPS:
    Interesting GPS choice. Where do you plan on mounting it?
    Jan 2006
    Cyprus
    the manual says it can be placed anywhere. i've been thinking to mount it behind the TFT or on the roof, in the middle, where that plastic cover is.
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Check the fuse rating on the radio circuit. If its 20 amps or above you wil be fine. Mines been running strong this way for awhile now, in theory 15 amps will work to (this is what the M2 is rated at) but I run it on my 20 amp and have 0 issues
    Jul 2005
    AZ
    Quote Originally Posted by blk02si
    See http://forum.e46fanatics.com/showthr...t=fuse+diagram
    It'll take some review, but it looks to me like it's rated at 50 amps.. However there's another fuse involved that's only 5 amps. The Cig Lighter is 30 amps for sure though. Personally, I prefer the radio power to grab it from the harness...
    What do you think?
  1. WTB: 20 pin ATX Power Cable for Opus 120
    By Shelbrain in forum Classified Archive
    Last Post: 02-04-2006, 02:23 PM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  3. Power Switch between two AC sources
    By JohnChimpo in forum Power Supplies
    Last Post: 11-01-2004, 05:56 PM
  4. full ATX mobo and req. power
    By fishy in forum Power Supplies
    Last Post: 10-13-2004, 01:53 AM
  5. ATX power
    By BooJew in forum General Hardware Discussion
    Last Post: 07-07-2000, 06:45 PM
