If you have an auxilary input adapter hooked up to the shaker 500 headunit, and you press the auxilary button, it goes to the auxilary mode. If you turn the car off while in auxilary mode, and then turn the car back on, does the radio start up in auxilary mode? I need to know because I may hook my laptop's sound up in auxilary mode, and mount the shaker headunit permanently behind the dash. In its place I am putting a 7 inch monitor, so I will not be able to access the still functioning shaker headunit. I want the car to startup in auxilary mode so my laptop's sound will funciton through the speakers.
