Results 1 to 4 of 4
Thread: Need advice on how to procede
    May 2006
    I recently purchased a used 97 honda civic ex(45k ) which has a factory tape player. I learned that if i removed the factory tape player that the keypad would no longer function. So i check the back of the unit(tape drive) and saw this white multipin connecter which i believe is a cd changer input.
    What i want to do is simply plug an mp3 player into my car would this be the best way? Which adapter do i need and do i even know what im talking about? Will i be able to pull audio from the cd changer plug just by pushing the cd/tape button on the radio?
    May 2006
    This is just a guess here, but perhaps this is what you're looking for? HON03/PC-SON 2003-06 Honda Changer Interface/Auxiliary Adapter
    Again, I'm just guessing, I'm not even sure if that will work with your car.
    May 2006
    is their any other way to do this?
    Elsewhere
    Quote Originally Posted by dx11101
    This is a forum that focuses on installing cvomputers into vehicles. Aftermarket audio equipment for your Honda isn't the specialty here. I tghink you might get a faster response with more information by posting on a forum that focuses on either Hondas or Car Audio specifically.
    That said, you were given a solution, although not ideal in your book. Yes there are other solutions, but that is likely the best solution that the respondant could come up with for you.
    If you want a simple solution, get an FM modulator or a casette adapter and rock on. If you want a decent solution, then you've got some research to do.
    How about the Wiki?
  1. Small Car, budget complete setup advice
    By Scouse Monkey in forum Car Audio
    Last Post: 07-14-2010, 12:17 AM
  2. need some advice building a car PC!
    By dsmstunna in forum Newbie
    Last Post: 01-23-2006, 02:03 PM
  3. case advice needed
    By michfull in forum Newbie
    Last Post: 12-19-2005, 10:56 PM
  4. Another newbie looking for advice on hardware
    By cid_mcdp in forum Newbie
    Last Post: 06-29-2005, 11:47 AM
  5. Advice on Setup...
    By blackout03specv in forum Newbie
    Last Post: 06-29-2004, 10:36 PM
