im running a 10 gauge amp kit to a 400 watt 800 watt max power inverter. 10 gauge is perfect if not overkill for that power supply. so your good to go
Originally Posted by 05k20A3
how can you tell him that 10 guage is overkill for his amp if you dont know how the current ratings of the amp(s) he's running?
that being said. how many amps do your amplifiers draw?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
Im running a 4 gauge from the battery to a distribution block, then 14 guage from distribuition block to my M1-ATX (90W). I also run 8 guage to two amps from the distribution blocks. and I have a 4 guage ground to a ground block, and again 8 guage ground to each amp.
Civiputer: Dont have one anymore, but here is what is used to be!
this table will help you figure out what gauge wire you need for your amps and pc:
http://www.powerstream.com/Wire_Size.htm
M10k
My Car Pc Install
My Boat Pc worklog
because he's not running an amp he's runnin a little dc-dc powersupply like i said 10 gauge is over killOriginally Posted by scott_fx
SORRY DIDNT READ THE LAST PART ABOUT THE AMP MY MISTAKE
if your just runnin this
http://www.mp3car.com/store/product_...roducts_id=171
10 gauge is fine
but if you also tryn to power amps like me n nameeri do. then go with 4 gauge to a distro block from there you can run 8 gauge to your amp and 10 gauge to your dc-dc power supply. if your doin two amps speakers n subs then do what nameeri does
hi,Originally Posted by scott_fx
I am using kenwood 350W amplifier. and M2-ATX, thanks.
Originally Posted by nameeri
I think, I will do exactly the same like you, run 4 gauge from the battery to a distribution block, then 14 gauge from distribution block to my M2-ATX 160W) and I ran 8 gauge to my amp, (300W 2 channel amplifier). Do I need a fuse for the amp ? I already have the fuse from the battery to the distribution block.
and. from the ground, How can I gonna to wire ? because I only have 1 input for my distribution block, so that's from the +(positive) to a distribution block, then for the ground how can I gonna to wire ? thanks.
I have the distribution block same like that, My question is there is only 1 way for the positive + from the battery to the disitrution block. And how about the ground for the distribution block ? where I can wire it, thanks
