Results 1 to 10 of 13
Thread: What i need to carputer, complete list?
    May 2006
    Finland
    Hi,
    it's obvious, that i need display, motherboard, memory, hdd, psu, case and so on, but what else i need?
    Some kind of shutdown/startup controller?
    I was thinking these:
    1 x Ampie Car Computer Case
    1 x VIA EPIA M10000 Mini-ITX Mainboard
    1 x M1-ATX 90 Watt - Smart Automotive Power Supply
    1 x Lilliput 7" VGA Touchscreen 619GL-70NP
    1 x IDE to Mini IDE (2.5" hard drive) cable
    1 x Pioneer Slot Load DVR-K05 DVD±R/+R DL/±RW Dual Drive 8X
    or would it be better to build the first carputer from mATX parts?
    Sep 2005
    If you've got the cash, go ahead and buy all the stuff and see how it goes. That looks like a decent list and you'll be fairly happy with it. Some additional items I don't see here...
    hard drive
    ram
    usb to ide (for connecting pioneer drive to motherboard for dash mounting (vs. mounting in the ampie case, if that's even possible).
    May 2006
    Finland
    Quote Originally Posted by peecee
    hard drive
    ram
    That's right, previous list did not include hdd&ram, because i'm going to use my old parts.
    Pioneer cd/dvd is meant to be dash mounted...
    So i will add "usb to ide" adapter to my list....
    Is there anything else, i MUST have?
    Constant Bitrate icecore's Avatar
    Aug 2005
    Estero, FL
    Caaaaaaaaaaables, please calculate the cost of cables and adapter, connectors etc in. You'll see it adds up pretty quickly.
    Asus MicroATX with GeFore 6100, Mobile Sempron 3300+, 1Gig Ram, 320GB 3.5" 7200UPM HDD, M2-ATX, Gain/Xenarc 7"
    Fast IS my copilot
    Apr 2006
    that's pretty much the same set up i am doing.
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Basic setup...looks good....
    I suggest:
    USB WiFi adapter
    USB GPS
    Some kind of more detailed Sound Information. If you dont have an amp, consider it, also, you need some way to integrate the sound into the car, ie throught the head unit or directly to amp.
    other than that...looks good
    Oh and some kind of I/O device, like keyboard and mouse...even if the screen has a TS, you never know when you may need to type something, at least during set up.
    Brown 2010
    Newbie joego's Avatar
    Apr 2005
    Including cables you have a good starters kit. Once you get going you'll find you'll want to add stuff like: cameras, GPS, radio, HUD, OBD-II integration, sound card, to name a few.
    Good luck with the install
    42
    May 2006
    Finland
    USB WiFi adapter - no need for this
    USB GPS - will come later
    I'll be using 2 amps, smaller one (MT-504) for speakers (SPLDynamics EXT-6.2) and bigger one (DIG-1450) for sub (SPLDynamics PRO 12D4).
    No need for mouse, i'll use keyboard...
    How "good" is integrated line-out, need for pre-amp?
    ......in progress......
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    before you buy ANYTHING setup a wiring diagram... you need to know what gauge wires you need, how long the cables will be and where everything will be located
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Mar 2006
    NJ/RI
    Wire gauge is very important. you definatly do not want to skimp out here, you can end up not being able to get your unit to start. Also a wiring diagram is a necesity. If you dont know how things are going to be hooked up before hand, something will be forgotten and the troubleshooting can be extremely frustrating.
    Brown 2010
  1. Replies: 16
    Last Post: 05-12-2005, 01:50 PM
  2. FS: complete carputer setup
    By wy3134 in forum Classified Archive
    Last Post: 05-05-2005, 12:00 PM
  3. My complete shopping list.
    By mpfjr in forum Newbie
    Last Post: 01-27-2005, 09:11 PM
  4. Complete Carputer
    By fabiolover2002 in forum Classified Archive
    Last Post: 06-26-2004, 04:30 PM
  5. For Sale Complete carputer
    By rb8720 in forum Classified Archive
    Last Post: 03-08-2004, 12:21 PM
