Results 1 to 10 of 12
Thread: Mistake or not???
    Newbie onefastaprilia's Avatar
    May 2006
    Illinois
    Mistake or not???
    I bought a aopen pandora Dual core minipc and after reading a ton of posts on here about a simular one I noticed my model was different they were talking about the single core I guess but now I am worried I got the wrong one and that I am going to have problems with this one and I ran a search on here for the dual core model and nobody said anything about it. the specs are:
    Technical Specifications
    DVD-ROM / DVD-RW super drive
    6.5 in X 6.5 in X 2 inches
    CPU: Intel Core Duo 1.66Ghz - 2.0Ghz
    RAM: 533/667Mhz DDR2, 1X stick, 512MB or 1GB
    Hard drive: serial ATA 2.5" up to 100GB
    GIGABIT Ethernet 10/100/1000 bt
    Unlimited expansion with USB2 & firewire 5.1 audio output, microphone input, internal speaker
    New in box 2X USB, 1X firewire
    backward compatible with USB 1.0 / 1.1
    internal expansion slot for 802.11 b/g network card
    DVI (VGA compatible) video out, HDTV out
    S-video (composite compatible) TV output
    high performance / low heat / low power requirement
    - Ideal for continuous operation.
    * Nero CD Burning software CD and Drivers CD included *
    Now I will list the components I can buy for it and put an astrick but the one I was going to buy and please tell me if I am overdoing, or getting too much for a carpc. and will I have power issues?
    1. Processor:
    1.67Ghz Core Duo dual core
    1.83Ghz Core Duo dual core
    2.0Ghz Core Duo dual core ****************
    2.Memory:
    512MB SDRAM
    1GB SDRAM******************
    3. Hard drive
    40GB HD
    60GB HD
    80GB HD
    100GB HD****************
    4. Operating systerm
    Windows XP media center Edition**************
    5. Wireless network adapter
    Internal 802.11 b/g wireless network adapter***********
    that is what I am thinking about getting for my bare bones pandora dual core am I over doing it or not and where could I get compatable parts for this model as the place I bought the dual core pandora is pretty expensive as far as there other parts for it.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    As long as you can power it.... you sould be fine.
    Look at the power requirements by rail ( 12, 5, 3) and make sure youe power solution can cope.
    Note: you will get faster resumes from hibernate with 512 mb ram instead of the 1gig.
    TruckinMP3
    Read the FAQ!
    May 2006
    Illinois
    I was going to power it with a Carnetic cnx-p1900 140W Dc-DcPSU
    May 2006
    Illinois
    here is a link to aopens website on the one that I have. It is the mp945-vx model.
    http://www.minipc.aopen.com/us/spec.htm
    Jun 2002
    Colorado
    Quote Originally Posted by onefastaprilia
    That's nice, I am not interested in reading the specs and telling you the answer.
    That is something you need to do.
    I have given you the information you need to go look. After you do that post any actual questions you might have.
    If you want a carPC, it involves doing some work and some learning.
    TruckinMP3
    Read the FAQ!
    Oct 2004
    NY
    the dual cores are pretty new, most here aren't going to have enough experience with them to know how much amperage they use... this is the main thing you need to research,... then search for power calculator & see where you stand after putting all your equiptment in to a power calculator..
    as far as it being overkill, yes it is, but theres nothing necissarily wrong with overkill unless it's trading off something else that's more important in the application... in your case both power draw & heat are your 2 main concerns... if these 2 things don't make it impractical then go for it
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    out of that lot I would go for the smallest processor as it will be plenty fast enough for a car unless your going to play games in it. Go for the gig of ram, I dont know why less ram would make it hibernate quicker as if it isnt in ram its in a page file and will have to be re-writen to the hibernate files. Am not saying your wrong Truckin just saying I dont understand. Either way your PC will run faster with more ram specially if your going to use GPS. As for hard drive its really up to you and how much stuff your going to put on it. Personally I can never have too much storage but partition the drive up as it makes things faster and also means you loose less if something screws up.
    May 2006
    Illinois
    thank you guys for your input as I have n o clue as to what im doing and never opened up a computer to change anything except the floppy to dvd drive on my dell laptop I am willing to learn as always. but I know this is what I would like in my car or I would just buy a eclipse touchscreen and add gps and sat tv and all the bells and whistles. Yes I probably am in way over my head and I am probably going to ask the stupidest questions and annoy everyone with them but I do not know much about computers heck I learned 3 days ago how to edit my logon and boot screen on my laptop. sorry But I do want this pandora in my stang I dont want to way overkill it but I dont want to underrate is either then end up buying another one in 4 months. I mean I dont know alot about this at all as I pretty much race cars, motorcycles and customize them for shows. I work as a paramedic/firefighter so there is my area of expertise. heck I still cant type worth a s**t either.
    Elsewhere
    If you don't know what you're doing, then I suggest you stop, take a deep breath, and do some reading about the aspects of the vehicle PC that you're unclear on.
    There is much to be learned, young padawan.
    How about the Wiki?
    Jul 2006
    okay well i can tell you this much it shouldnt draw anymore power than what the brick that comes with the computer states it draws which should be no more than 19amps plus heat yet this thing gets hot i have 20 of them sitting in a drawer at work for evaluations at intel. they get hot but they have speedstep so dont worry about it and 90% of the time the heatsink is cool to the touch its the hdd that heats things up that and the dvdrw drive doesnt help as well. this device will be VIIV compliant within a month or so i am already running VIIV on it right now i am actually installing this in my car and i have a freind that has already done it granted his is all sorts of rigged up but it works great.
  1. cheep Xenarc by mistake
    By CMOS in forum LCD/Display
    Last Post: 02-25-2006, 02:09 AM
  2. Carnetix P1900 (brand New Brought By Mistake)
    By rockyfozz in forum Classified Archive
    Last Post: 08-14-2005, 05:34 PM
  3. STUPID mistake I made - M1-ATX
    By sxt173 in forum Power Supplies
    Last Post: 02-20-2005, 11:33 PM
  4. Inverter mistake?
    By bulgogi777 in forum Power Supplies
    Last Post: 07-18-2004, 12:50 PM
  5. This forum is a mistake . . .
    By Dex4now in forum Newbie
    Last Post: 09-13-2003, 06:35 PM
