Results 1 to 3 of 3
Thread: login issues
    Registered User
    May 2006
    login issues
    im getting these errors at the beginning of windows. it says "windows cannot load the local profile. reasons; security rights not found or the local profile is corrupt."
    and
    "windows cannot find a local profile and is logging you in with a temporary profile. changes you make to this profile will be lost."
    also i tried reloading windows but the version that was given to me by mp3car didnt include the security key.
    Elsewhere
    Why are you posting this again in another subforum?
    Go into the User Control panel and create a new user.
    Reboot the computer (assuming that you still can after the attempt to reload Windoze) and log in as the new user.
    Also, I seriously doubt that mp3car.com store is going to sell you a copy of Windoze without the CoA & corresponding key. Is there a Windoze CoA sticker anywhere on the case? That's where OEMs are supposed to put the CoA sticker, anyway....
    How about the Wiki?
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    I'm assuming you can't login to Windows. Boot in to safe mode using the F8 key after the BIOS post screen and before the Windows XP logo screen.
    Login as Administrator. It will be easiest to create a new user under Start => Control Panel => User Accounts. You could also copy the Administrator profile to your user account if you wanted using the profile manager.
    If you are able to login to your computer (even in safe mode) you could use Magical Jelly Bean to find the key. http://www.magicaljellybean.com/keyfinder.shtml
    Did you get a CD from MP3Car along with a small "Windows XP" manual? If so, check for the small sticker called a Certificate of Autenticity (COA). That will have your product key as Darq has said.
  1. different gfx driver per user login?
    By Goofus in forum WinNT Based
    Last Post: 12-20-2005, 05:25 PM
  2. Verizon Novatel 620 issues
    By MobiTekLink in forum Wireless Communications
    Last Post: 12-02-2005, 03:35 PM
  3. Linux Login, UPS and Linux Touch Screen
    By polc1410 in forum Newbie
    Last Post: 02-11-2005, 10:43 AM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
  5. PHP..Im getting a bogus login prompt
    By PoBoy in forum Off Topic
    Last Post: 09-02-2002, 07:59 PM
