Results 1 to 5 of 5
Thread: How I can find my ignition for kia 2002 spectra ?
    Mar 2006
    Hi guys,
    Sorry, I really need help to find my ignition, my car is kia 2002 spectra, I really need to find my ignition, because I need to connect the remote from the amp to it, and the amplifier only turn on once I start the car. am I right ? and for the power supply M2-ATX, do I need to connect any wire to ignition, so once I start the car the my power supply will turn on. Thank You.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Talk to a local car stereo shop (unless someone on here chimes in), they will tell you which wire to tap on the radio wiring haness.
    2005 Ford Focus ST
    Elsewhere
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If you don't have a multimeter yet, BUY ONE NOW.
    Is the cigarete lighter only hot when the key is in the ignition and turn to 1 and 2 click? If you said yes, there is the ignition wire.
    If you said No, take the radio out. On the wire harness on the back, there SHOULD be 1 wire that is HOT only when the key is turn to 1 and 2 click. Make sure you turn off the radio.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jan 2006
    according to this diagram, your ignition is the grn cable from ur wiring harness
    va158858.pdf
  1. What's with the sudden flood of newbs?
    By ShinkunoNamida in forum Off Topic
    Last Post: 03-29-2007, 02:43 PM
  2. Where do i find the ignition switch
    By arawas in forum General Hardware Discussion
    Last Post: 01-14-2006, 01:04 PM
