Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Thread: Powered USB hubs
  1. #11
    Low Bitrate 2000Jeep's Avatar
    Mar 2006
    Quote Originally Posted by W3bMa5t3r
    Just make sure your polarity is right.
    How is the best way of doing this?
  2. #12
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by 2000Jeep
    well your ac power adapter should say which part of your plug is positive and which is negative, so taking that, and a multimeter, check the wires (once you cut the plug off from the adapter, and see which wire matches up with the positive/negative respectively. use the continuity/beep/short setting on the multimeter.
  3. #13
    Apr 2006
    intersting... but what if you need something like 8 volts, where do you draw this from... or would you use the 12v line with a resistor?
  4. #14
    May 2006
    Perth, Australia
    What would you possibly need 8V for ?
  5. #15
    Apr 2006
    Quote Originally Posted by Un_discovered
    I have two usb hubs, one uses an 8v input, the other 3v... hence my question!
  6. #16
    Apr 2006
    Washington, DC
    Provided my memory serves me correct, yes, you can use resistors to drop voltage ;-). to figure out how much resistance for the correct voltage drop, you'll need to use Ohm's Law :-)
  7. #17
    May 2006
    Perth, Australia
    That's really bizzare, considering USB ports are 5V
  8. #18
    Apr 2006
    Washington, DC
    Ditto... cuz even my 7 port hub (d-link) runs off 5vdc external... but hey... every manufacture to their own I suppose...
    Damn it's waayyy to early for me to be up... off to work I go...
  9. #19
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    if you use a 12v as + and the 5v as - you'll get 7v
    I dunno how safe it is to do this, but I've done it before on a homebrew fanbus i made. 5v wouldn't start some of the fans for a low speed, but 7v would.
  10. #20
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    Quote Originally Posted by kamikaze2112
    If you use a 5V line as the ground on the USB hub, it's possible that the 5V would be shorted to your car's ground through the USB cable. If not that, then say perhaps you have a USB touchscreen plugged into the hub, which would short the 5V to your car's ground through your touchscreen monitor which is properly grounded..... both examples are only theoreticals, but the point is that there are a lot of ways the 12-7V trick can fail. It works on fans and such because they are simple, isolated devices which don't share any other connections.
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Replies: 197
    Last Post: 06-15-2006, 09:47 PM
  3. USB Hubs / Powered or not
    By Scafremon in forum General Hardware Discussion
    Last Post: 06-15-2006, 09:03 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  5. Quick question regarding usb hubs
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 04-12-2005, 09:18 PM
