Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Powered USB hubs
    Low Bitrate 2000Jeep's Avatar
    Mar 2006
    Powered USB hubs
    I have and and but im going trying to find the answer.
    Please someone one help me with this. I have a powered usb hub. I understand that i need 5 volts to power it. Im pretty sure i can get it off my m2-atx power supply. My question is how in the hell do i do that. Do i just get a plug and cut the wires and hook it up to the power supply? if so where do i hook it up on the power supply?
    Elsewhere
    Tap into a 4-pin molex connector (otherwise known as a HDD power connector).
    Red = +5v
    Yellow = +12v
    Black = Ground
    How about the Wiki?
    Mar 2006
    cool thanks.
    so i just take like the wall adaptor and cut the plug off and plug it into a molex connector?
    Mar 2006
    damn double post
    here is my hub
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Quote Originally Posted by 2000Jeep
    cool thanks.
    couldn't tell if you'd done it already, but yeah, if you're not going to use the hub in the house anymore, yeah, just cut the plug and wire it in. Just make sure your polarity is right.
    Mar 2006
    Cool, thanks guys
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    red wires on the molex, not the yellow ones...
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Mar 2006
    ok, yellow is a no no, red is a go
    Apr 2006
    Washington, DC
    LOL sweet... but yep.. you got it, at least in this application
    Mar 2006
    thanks guys. I got to get power to the hubs and tot he PC then work on my detachable faceplate again (check link at bottom) and get it installed then hook up my new amp and sub then i should be done.
    http://mp3car.com/vbulletin/showthread.php?t=76669
  1. Best mountable, DC powered USB Hubs?
    By Dan Marsh in forum General Hardware Discussion
    Last Post: 05-19-2010, 03:34 PM
  2. Replies: 197
    Last Post: 06-15-2006, 09:47 PM
  3. USB Hubs / Powered or not
    By Scafremon in forum General Hardware Discussion
    Last Post: 06-15-2006, 09:03 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  5. Quick question regarding usb hubs
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 04-12-2005, 09:18 PM
