Results 1 to 10 of 17
Thread: Advice on location, size, and setup of the lcd in a durango
    May 2006
    I am in the process of setting up my first car computer. I have a 98 durango. The computer part is fully taken care of, but I am trying to figure out the best way to put the screen in, and what size screen to get.
    Here is what I am 'thinking' of doing at this moment, and I am looking for the advice from someone who actually knows the pros and cons to a setup like this.
    I would like to get this item (or similar): http://www.mobilevideo4less.com/Merc...ory_Code=BRKTS
    and mount it where that lcd screen is sitting in the picture (the durango has a little tray right there on the floor), then put the screen on the end of the gooseneck (please note this is just a random image so people can see what I am trying to do).
    I am also looking to any input on using either an 8" or a 10" screen. I do not know if a 10" is 'too big' or just will be obnoxious with this type of setup.
    I am sorry if this is a rediculous type of information to request, I would just like to make sure it will look good (maybe someone has experience with this type of setup) and work properly.
    Thank you.
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    ******* DODGE ripping off dead director!!!
    for second i though it was related to that cute sports car from clockwork orange.
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    My GF has a Durango and I have stared for hours at the dash trying to figure out a good way to get a screen in there. Unless you are a master fabricator you are pretty much screwed. I don't like the gooseneck solutions. Looks too "added on" and also very attractive to potential thieves.
    Good luck with it, and if you do fabricate a way then make 2 while you're at it and send me one.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Constant Bitrate Matrix_24's Avatar
    Jul 2005
    IL
    look in my sig
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by Matrix_24
    look in my sig
    Great install, but you didn't have the 4WD shifter to work around.
    Jul 2005
    IL
    Quote Originally Posted by edrex
    No, I have the electronic shift. He is using a 7", I am sure that can be made to fit around the shifter. Mine is an 8" and I made the mount a lot bigger than it had to be just to take up space. If I had to I could probably make the same mount for a 7" LCD and still leave room for the shifter.
    FLAC edrex's Avatar
    Dec 2004
    Is that an offer?
    Jul 2005
    IL
    Is that an offer?
    If someone could loan me a Durango in my area I would love to do another one.
    May 2006
    thanks for the input guys - and matrix, i have read that thread probably close to 10 times already very nice install.
    I am working with a lillput 8". I DO have the 4x4 shifter to work around. And I really do not want to have it as low as matrix's. I guess I am probably out of luck unless I decide to relocate my vents and do some fabrication. :/
    Jul 2005
    IL
    Quote Originally Posted by mattz0r
    thanks for the input guys - and matrix, i have read that thread probably close to 10 times already very nice install.:/
    With an 8" you are kind of limited to the dash then. The only thing I did not like about that dash is that it is one huge piece and was hard enough to work with just changing the radio out. There are not too many ways to go in the Durango. Post pics when you decide on what to do, I am interrested in what other people will do with their Durangos.
  1. Small Car, budget complete setup advice
    By Scouse Monkey in forum Car Audio
    Last Post: 07-14-2010, 12:17 AM
  2. what size inveter should i use for this setup
    By saintvice in forum Newbie
    Last Post: 12-10-2005, 03:07 AM
  3. Doing a carpc setup, questions/help
    By Punisher in forum General MP3Car Discussion
    Last Post: 08-28-2005, 01:44 PM
  4. Replies: 2
    Last Post: 07-01-2005, 06:20 PM
