Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: tapping into stock radio harness for igntion power?
    Mar 2006
    can i just tap into the power wire that would turn my stock radio instead of tapping directly into the ignition wires?
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    yes, or, which is easier, you can tap into the cig lighter, it (in most cars) only comes on with the acc position. this is where i got my "ign" from.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    If you do that make sure you test it first. My cars all have at least one power outlet that is always on.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Mar 2006
    does anyone know where i can find the radio wiring diagrams for a 2001 vw golf?
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    Quote Originally Posted by VW_Carputer
    I don't have it, but if you have the radio pulled you can easily find it with a test light or a multi meter.
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    The VW vortex forum has all that you need.
    http://forums.vwvortex.com/zerothread?id=1835863
    From there scroll down to the 'Interior electronics' tab.
    I've found all the wiring details for the stock Monsoon hu it's amp and the wiring harness for the optional cd changer.
    I've done alot with the cd changer wiring. It runs from the back of the Hu to the trunk/hatch area. I loped off the connectors and installed power connections and control switches for the pc/inverter that I have mounted in
    the trunk.
    Mar 2006
    im a member on there but i cant find the diagram
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    A lot of 12VDC cigerette lighter outlets are not switched and will always remain hot. This is a safety feature that some manufacturer's do to ensure that the outlets can still be used in the event of an emergency (ie. to charge/use a cellphone). Your best bet is going to be the IGN line going in to the radio. Remember, atleast one wire is going to be constant 12VDC. This one retains the memory to the stereo. This is not the wire that you want. Like a few others have said in this thread, get a multimeter. It doesn't have to be that expensive. Mine was twenty dollars from RadioShack and it was money well spent. It is probably the single most used tool when it comes to putting stereo/CarPC equipment in the car. Using the multimeter, find you wire that puts out 12VDC when the car is on or in ACC. Turn the car off. If the voltage disappears then this is the wire that you want to tap in to.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Mar 2002
    Austin, Texas
    Quote Originally Posted by fixerofallthing
    Here is the part of the diagram you are aking about.
    Looking at that wiring diagram (which looks incomplete) it looks like the yellow/red wire is the one that you are looking for.
    But this diagram does not look like it really shows the stereo. It shows the wires from the ignition going in to what appears to be some sort of control module but does not show the actual stereo. Look at the speakers. Where are those wires coming from...? That's the portion of the diagram that I think would help the most.
    Derek
    EDIT: Looking at the double-din Monsoon sub thread someone says the gray wire will work. This wire does not react with the ignition but instead is hot when the stereo is on.
    EDIT2: Per the12volt.com wiring diagram for a 2000 Jetta:
    Code:
    2000 Volkswagen Jetta Stereo Information
    Constant 12V+	Red/White
    Switched 12V+ 	Gray/Blue
    Ground    	Brown
    Illumination 	n/a
    Dimmer  	n/a
    Antenna 	Left Front
    Front Speakers 	6 1/2" Doors
    Left Front (+) 	Blue/Black
    Left Front (-) 	Orange/Blue
    Right Front (+) Red/White
    Right Front (-) Orange/White
    Rear Speakers 	6 1/2" Rear Doors
    Left Rear (+) 	Red/Light Green
    Left Rear (-) 	Orange/Black
    Right Rear (+) 	Blue/Light Green
    Right Rear (-) 	Orange/Red
    Looking at this, I'd say Gray/White is what you're looking for. (PS. I am not familiar with Jetta years so hopefully the 2000 and your 2002 are similiar.)
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. CarPC with stock radio integration
    By jnye6625 in forum Car Audio
    Last Post: 12-01-2005, 12:40 AM
  3. Radio Antenna / Power Extension Cables
    By vatik in forum General Hardware Discussion
    Last Post: 11-17-2005, 12:21 AM
  4. Addon to Stock radio
    By EBFoxbat in forum Car Audio
    Last Post: 09-22-2004, 01:16 PM
  5. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
