Results 1 to 5 of 5
Thread: help choosing. ?
    Apr 2006
    help choosing. ?
    Hi i'm a newbie, i have read the PSU threads/faq but can find what to do..
    i use the calculators to see my wattage requierements http://carpc.kyferez.com/Tools/PSUWattageCalculator.php and i end with a total of 198 watts.
    My system would be.
    1- ECS k7S5A motherboard
    1- Athlon XP 1500+ with high performance fan
    1- DDR 512mb(or maybe 2 sticks 256mb ea.)
    1- IDE hard drive 7200 rpms
    1- PCI sound card (sound blaster live)
    1- CD-RW
    1- USB gps
    2- serial devices connected using serial to usb converters
    1- serial device
    1- touchscreen screen
    i was considering the M2-ATX.. so what is another option in the same price range ??
    Thanks a lot guys.
    Mar 2006
    Colorado, but Canadian!
    Do you mean another option power wise? The Opus is comparable and is some people's minds better. Bit pricier, but in the same "range".
    Apr 2006
    Well i mean something that can meet my requirements. Because if that calculator is kinda exact saying i need 198 wattas , and the M2-ATX is rated at 160 watts. i will be way off
    So what are my options ?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    you need to work out what power you need on what voltages not just the total power. Only car power supply that big I think is the DSATX but your still far too close to its max and might well be over on one of the lines. You either need to reduce the power you need or go over to an ATX supply and an inverter setup.
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Be careful about listening to this, but when I ran the power calculators it said I needed over 200 (210-220, can't remember exactly how much). I took a chance and went with the Opus 150 and it has worked flawlessly with my setup.
    To take a little load of your PSU power your monitor off the cars ignition line instead of through the PC.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
  1. Replies: 8
    Last Post: 02-25-2006, 06:58 AM
  2. Help choosing an LCD
    By BMW_525i_N00B in forum LCD/Display
    Last Post: 02-16-2006, 11:15 AM
  3. Replies: 1
    Last Post: 10-13-2005, 01:18 AM
  4. help on choosing a touch screen monitor???
    By slvr430ml in forum General Hardware Discussion
    Last Post: 05-10-2005, 12:05 AM
  5. Need some advice on choosing scan converter
    By Neopham in forum LCD/Display
    Last Post: 01-06-2004, 02:03 AM
