Results 1 to 9 of 9
Thread: Guys, please help me powering my xenarc with P4 Connector ?
    Mar 2006
    Hi guys, My motherboard doesn't need to use a P4 connector, so I think I am going to use that P4 connector to power my screen, but I don't know which wire I should connect to ? there are 4 spots of the P4 connector. By the way, I have a extra monitor power cable.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Do you ever search for anything???????????????
    Its called a 12V power connector
    1 & 4 are +12VDC Yellow
    2 & 3 are COM Black (Ground)
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Elsewhere
    Quote Originally Posted by Quattro
    I highly doubt it.
    How about the Wiki?
    Mar 2006
    Hmm...I did do some searching guys. But didn't find anything good. so anyways, yesterday, I tried to power my xenarc with 12V power connector, I have no idea which one will connect to. So I just tried to connect around and I ended up with my computer just automatic shut down, I was lucky, it didn't damage anything on the screen or computer. So can you guys please tell me which 1 ( 1-2-3-4 ) on the 12v power connect I should connect to the screen. Once again, thank you very much.....
    Low Bitrate dune's Avatar
    Dec 2003
    Dallas, Texas
    Connect positive to one of the yellow pins and negative (ground) to one of the black pins, should work fine. If you have problems, make sure you're not shorting something and put a voltmeter on the leads to check voltage.
    tango/dune
    Infiniti QX4 2002 project (done!... for now)
    Dec 2003
    New York
    Quote Originally Posted by shinjetko
    Liar.
    First result on google.
    http://www.google.com/search?hs=Hy7&...ut&btnG=Search
    Installed
    Elsewhere
    He didn't say WHERE he was searching. He could very well have been searching WebMD or perhaps the menu for McDonalds.
    How about the Wiki?
    Mar 2006
    come on guys, don't be like that man,
    Elsewhere
    Don't be like what?
    Brutally honest about the fact that you say you searched, yet the information is readily available through a simple Google?
    You're talking about moving elctricity from one place to another. If you **** it up, you could hurt yourself, destroy your computer or your vehicle.
    I highly suggest you learn a couple things before you begin to go cutting into power cords.
    How about the Wiki?
  1. Replacing connector in Lilliput
    By Chairboy in forum LCD/Display
    Last Post: 05-04-2005, 11:31 AM
  2. For you P4 guys!
    By Rafster in forum General Hardware Discussion
    Last Post: 04-15-2005, 08:28 PM
  3. Question: Powering Xenarc from Morex 80w?
    By eleventh in forum Power Supplies
    Last Post: 12-05-2004, 09:58 AM
  4. Xenarc crappy connector!
    By Shadow in forum LCD/Display
    Last Post: 05-04-2004, 01:36 AM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
