Results 1 to 6 of 6
Thread: reboot prob
    Low Bitrate LVExpo's Avatar
    Oct 2005
    Las Vegas
    reboot prob
    when i start my car with my computer already running, the computer reboots sometime and i also get a blue screen from time to time.
    anybody know why???
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    Probably insufficient power during engine crank.
    Elsewhere
    Mine does this, too.
    I suspect that I've getting a voltage spike, and I can adjust the tolerance of my DSATX to accomodate. I'm logging the output of the DSATX to confim my suspicion.
    What are you doing to troubleshoot your condition?
    How about the Wiki?
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Try going into the bios and turning off the setting that alows the computer to reboot after power loss...ie set it to stay off. This way, when you start the car, if the computer shuts off completely, you know its insufficent power during engine crank.
    What PSU are you using? You may want to consider re wiring...I have found that if you run the PSU straight from the +12v on the battery, you get better juice and even during hard engine cranks, the power stays fairly level.
    Brown 2010
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Also depending on where your turn-on signal is coming from, some cars shut down the ACC line when starting to preserve power for the starter. You may need some diodes to combine the ACC and IGN line so it'll keep crank.
    Mar 2006
    NJ/RI
    Ahh...thats a good point.
    But would that reset the computer?
    Brown 2010
  1. Second battery prob..
    By BuNNy-RaBBiT in forum Power Supplies
    Last Post: 11-07-2005, 06:18 PM
  2. M1-ATX quit during reboot?
    By BADDERICK in forum Power Supplies
    Last Post: 07-14-2005, 09:44 PM
  3. Minlogon Reboot Loop
    By jessebs in forum WinNT Based
    Last Post: 07-08-2005, 08:34 AM
  4. Replies: 15
    Last Post: 12-03-2004, 09:11 PM
  5. Via Epia M10000 random reboot
    By patchan in forum General Hardware Discussion
    Last Post: 06-13-2004, 05:37 AM
