Results 1 to 10 of 15
Thread: Extreme noob question about Cigarette lighter port
    May 2006
    I have a 1990 Nissan Sentra, and I just bought a ipod connector that plugs in through the cig. lighter port,and to my ipod. I was wondering If the car is turned off, would it be ok to leave the connector in the cigarette charger or would it drain my battery over time. If anyone could give me a for sure answer I would highly appriciate it. I wouldnt want my car to run out of battery power on some random road or anything. Thanks
    Newbie 3D Warrior's Avatar
    May 2006
    Welland, ON
    Quote Originally Posted by Leviathanmike
    if the car is off all the electronics are shut down so it'll not drain the battery.
    Mar 2006
    probelly not. look at your ipod battery compaired to your car battery. i would try to charge while your car is running but as long as the cig charger has a overcharge protection which most have it should be fine.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Depends on the car. Does your lighter socket turn off with the key or does it stay on all the time? If it stays on all the time, it probably has NO PROTECTION ON IT. Especially on a 1990 model.
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Don't think cars had the always-on cigerette lighter plugs back then. Just look to see if your iPod is charging when the car is off and that will tell you if you can leave it hooked up.
    Derek
    PS. Just be sure to keep it out of sight when you're not around. Someone may decide that they may need it more than you do. Happened to me with my radar detector...
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    May 2006
    thanks a bunch guys
    May 2006
    Calgary, Alberta
    Cigarette lighters are on a switched 12 volt source. The car shuts off all power to it when the car is off for safety reasons. So you can jam your fingers in there if you want while the car is off and nothing will happen.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    San Diego, CA
    In my car the cig lighter stays powered. I think in newer cars they started doing this so you could power a cell phone if the car would not start. I know when my phone charger is plugged in, the LEDs stay lit when the key is out of the car. You should be able to leave the ipod plugged in and turn off the car and see if it charges or not. If it does, it could drain the battery I would think. if it does not, then it answers your question...
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
    Apr 2006
    My lighter is a 12 volt constant source.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Maheriano
    Not true for all models. Our suburban stays powered but the toyota does not.
    TruckinMP3
    Read the FAQ!
  1. noob question about wiring
    By VW_Carputer in forum Newbie
    Last Post: 05-24-2006, 09:33 PM
  2. Total Noob Question
    By free cable pron in forum Newbie
    Last Post: 04-15-2006, 05:01 PM
  3. noob question temp sensors
    By yamathegreat in forum Road Runner
    Last Post: 02-07-2006, 05:54 AM
  4. Noob Here with a question...
    By ImprezaRS-T in forum Power Supplies
    Last Post: 03-15-2004, 06:09 AM
  5. splitting cigarette lighter for inverter
    By jshrieve in forum General Hardware Discussion
    Last Post: 03-25-2001, 06:51 AM
