Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Do I need a cap?
    May 2006
    Calgary, Alberta
    Do I need a cap?
    I got a rockford 250m amp pushing a 12 inch Rockford sub that's been going fine for years without a cap. But now I'm going to have the computer hooked to the battery and also an amp hooked to 4 stock speakers. Am I going to need a cap so I don't kill my alternator and battery? How am I going to get all that clamped onto one battery terminal?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    San Diego, CA
    I know next to nothing about car audio, but as far as connecting it all to your battery, I think you need a power distribution block. Can anyone confirm this?
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
    Elsewhere
    Distribution block, yes.
    How about the Wiki?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    250 Watts? no you dont need one. i've got 1600 rms and i'm not running one
    Live mp3Car Facebook Chat
    May 2006
    Calgary, Alberta
    2 for yes and one for no. Anyone else?
    And what's a Distribution Block?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    San Diego, CA
    That is 3 for yes I think. The no is for the 2nd question about a cap.
    A distribution block:
    http://www.crutchfield.com/S-euvIWre...ribution+block
    I think it is a way to connect one cable from the battery, and then have more connections/terminals. Someone correct me if I am wrong...
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/showthread.php?t=77267
    May 2006
    Calgary, Alberta
    Ah, I thought they were all yes for cap.
    So this isn't going to give my bettery / alternator a heart attack having these three hooked to the battery? My dome light already buzzes dimly when it comes on.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    you do not need a CAP, this is all you need to do
    step 1:
    run 6ga or smaller to the trunk(or whereever amp/carputer are)
    if not already 6ga or smaller upgrade your ground wire from the battery to the chassis
    step 2:
    install a power distro block in the trunk at the end of the 6ga wire.
    find a good ground point(like a big bolt or something, remove it, sand the paint off from around the hole the bolt went in until you get to clean metal.(this is where your ground connections will go)
    step 3:
    use 10ga wire from the distro block to your carputer PSU
    use 10ga wire from the distro block to your amp
    use 10ga wire from your new clean ground point to your carputer PSU.
    use 10ga wire from your new clean ground point to your amp.
    step 4:
    (cheating step)
    run a 14 or 16 ga wire from your amps 'remote' wire(usualy blue) to your carputer psu(ignition switch/sensor input)
    OR
    run a 14 ga wire from the carputer PSUs ignition sense input to the steering colum harness and tap into the ignition on or acc wire(or find something else in the car using a DMM that is hot ONLY when the key is in the ACC or IGN position.
    unless you are not telling us about your other amps you do not need a CAP.
    but if you did:
    before the distro block to the positive side you attach to the CAP, on SAME side you attach the distroblock.
    on the other side you run your 6ga ground wire to the cap, then on SAME side you attach all your grounds.
    (note: if you have a NEW cap, it needs be charged before you can actually use it properly(ie. RTFM)
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    May 2006
    Calgary, Alberta
    Wow, that's awesome, thanks. One problem though, I have the 250 watt mono sub amp and I'm getting a 4 channel amp for my 4 stock speakers, plus the carputer. Does your answer of not needing a cap still stand? And with step 4, running the ignition wire, I don't just run it from the amp to the carputer right? You want me to splice into the amp lead for the carputer so it's still connected to 12 volt? Or do you literally mean running just the one lead wire from the amp to the carputer? I don't see this working as it still won't know when to turn on and off.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Woodbridge, VA
    Blog Entries
    32
    still stands.. you dont need a cap it would be a waste on such a low watt setup
  1. Mastero MK-4.5 250w 12v DC-DC ATX PSU + SDC
    By Mastero in forum Power Supplies
    Last Post: 09-25-2006, 11:15 PM
  2. Replies: 3
    Last Post: 04-11-2005, 03:22 PM
  3. Using a high farad cap to survive engine crank
    By lakorai in forum Power Supplies
    Last Post: 03-28-2005, 10:47 AM
  4. Using a 1-1.5f cap for makeshift tank.
    By skiingsean in forum Power Supplies
    Last Post: 08-29-2003, 02:14 AM
  5. Anit-Crank-Drop cap solution?
    By All4Norway in forum Power Supplies
    Last Post: 01-07-2003, 09:20 AM
