Why do you want to connect your CD changer to the PC ? I speak french also if you do?
hi every body
first i am sorry about my bad english
i ask about if i can conect my cd changer to my carpc and what part use
and control soud from my carpc or my cd changer device
hi kevinlekiller
i want to connect my cd changer device because i don't want to put my carpc screen in its place but i am searching for another place for my screen
so iwant to connect my cd changer to carpc because i want to keep it in its place
for this iwant to know how to do this work and what parts i need
kevinlekiller
i want to ask you another Question
can i wire the speakers (the orginal in car) into my car computer and play music on thier
thanks alot
By CD changer, you mean a CD player ; Example: Click me
And not a CD changer , example : Click me
To connect , you need to see if the head unit as a input , this can be a CD changer Input or a RCA female connector input.
If its a CD changer connector input you need something like this :
http://www.crutchfield.com/S-irsY6MP...p.asp?g=234650
You have a Renault , so Im not sure what brand of head unit Renault uses (stock) , it might be some brand that you cant find a cable , in that case you need to buy a new head unit with aux input ( rca female connectors ).
If you have Rca female connectors on the head unit , then you just connect that to the pc , with 2x male RCA to 3.5mm stereo connector.
Also , you can use an amp , then the PC connect to the amp , the PC acts as a preamp(instead of the head unit). This way , its easier to place the screen.
Hi. Does any know where I can get the same lead as what is needed in the previous post? Or know what make it is? Cheers
