Your first option is the FAQ Emporium, which has answers to 99% of questions you might have about a vehicle PC.Originally Posted by rabbitman007
For the LCD, look for model that has a transformer-style power brick, as you can likely produce the voltage needed with a DC-DC PSU. And 15" screen is HUGE for a vehicle, unless you drive a bus.
External slim DVD burner can be powered off the firewire or USB bus, although USB would require two USB connections (one for power, one for data)
Get a newer engine or a relay board, software and sensors, then be prepared to do some coding. The newer engine option is a lot easier.Also, with my car I am looking for a patch to monitor all of the guages (speed, tach, odometer, fuel, oil, water, etc) through the computer. However the car is an 83, with no ECU (car computer). Any ideas on what to do?
You need to make that decision.Linux or Windows?
LinkBack URL
About LinkBacks
