Results 1 to 10 of 13
Thread: SP1300 running SATA HD
    Oct 2005
    I'v searched but didn't quite get any clear results. Since Ill be purchasing a SP1300 MB and it supports SATA for hard drive. I can't find a good price for a 2.5" SATA hard drive, but found plenty of ATA. Is it possible for a SATA to be converted to ATA? I know that ATA have 4 more pins and the cable uses is more bulky which might cause air flow interference, but if it is my option, I might as well uses ATA rather then SATA. Thanks for the replies and help.
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by skygtr
    The 13k also has ata connectors onboard if I'm not mistaking...
    Newbie gabureiru.'s Avatar
    Jan 2006
    ATA cannot be converted to SATA
    Low Bitrate grimor2000's Avatar
    Dec 2005
    Chicago-ish
    Quote Originally Posted by gabureiru.
    yes it can, you just need a converter, I have one. you can find them on eBay farly cheap. Just look for IDE to SATA.
    I run a SATA drive on my SP1300, a Fujitsu MHT2060BH
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    sp13000 supports ATA as well so just get a normal drive. You could convert but there is nothing to be gained by it as it will have to work at the lower standard anyway. The adapters are also about 30 euro which probably comes prety close to a proper SATA drive anyway when added onto an ATA drive
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    You don't need a converter with the SP-13000. It has both SATA and IDE ports. I found 2.5" notebook drives with SATA interface for about the same price as IDE counterparts here:
    http://www.logicsupply.com/default.php/cPath/26
    But, I also read that the SP13000 needs some special windows install disk to support SATA drives. I am using a spare 20G IDE drive that I already owned so I am curious if the SATA is really faster and if the "special install" is simple and transparent or is it a PITA. Let us know if you try it.
    Grimoor2000: what is your experience with setting up the SATA?
    ~Jimmy
    Dec 2005
    Chicago-ish
    when setting up the Sata drive, you need the SCSI drivers on a floppy (and a usp floppy) OR you can make a custom XP disk that already includes them. You can (should) also include the SP's and updates while you're at it. here's how.
    http://www.maximumpc.com/2005/01/how_to_slipstre.html
    VIA SP13000
    1GB DDR400
    PCI TV/FM card
    Logisys FP800
    M1-ATX
    Elsewhere
    Quote Originally Posted by grimor2000
    They aren't SCSI drivers. They are SATA controller drivers.
    The prompt in the Windows install does say 'SCSI or RAID driver', though. Basically, the Windoze install needs drivers for any storage subsystem that aren't present natively.
    And you don't need a USB floppy drive if you have a FDD port on the motherboard.
    How about the Wiki?
    Oct 2005
    thanks for the replies guys, so to make sure, for the SP1300 board, I can just get the ATA and it is plug and play correct?
    Elsewhere
    Yes.
    How about the Wiki?
  1. Replies: 16
    Last Post: 03-02-2006, 11:05 PM
  2. Replies: 2
    Last Post: 07-19-2004, 01:25 PM
  3. noise from HD
    By gizmomkr in forum General Hardware Discussion
    Last Post: 12-02-2002, 02:54 AM
  4. HD mounting and buffering
    By Dimitris76 in forum General Hardware Discussion
    Last Post: 12-04-2000, 11:05 AM
  5. PDA cassio 105 connected to a HD??
    By prado_sergio in forum General Hardware Discussion
    Last Post: 12-30-1999, 09:55 AM
