Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: New To putting in a Carputer
  1. #11
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    welcome. another good resource for vw carputers is http://forums.vwvortex.com . If you find your way into the mk4 section and find the faqs there are some pretty awesome little writeups on dismantalling your car.
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    just be ready to wade neck deep through all of the bull **** that's over there...lol
    you think this place is bad?
    HA!
    Jan Bennett
  3. #13
    Jun 2006
    Gainesville, FL
    Thanks I was reading about the gauge, the thing is how am I going to connect it from the battery and run it to the trunk, I was think it would go out to the dash and then run along the carpet under the seats to the back. I frequent vwvortex but that place gives me a headache but I will check over there. thanks
  4. #14
    Mar 2006
    Colorado, but Canadian!
    Well I used a ring terminal on the end of a long wire and screwed that to the battery's actual positive terminal. Then it goes to a fuse (Always recommended), and then it runs down through the firewall (the metal between engine and cabin), and into the trim, where I loose it and it pops out by my pc. Since it is a 2001, it should be pretty easy to rip apart. My car, I just pull real hard in different areas of the plastic and it pops up.
    1.9in x 2.9in -- 47mm x 73mm
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    wait a second - you are lost as to how to physically run a wire from the front of your car to the trunk?
    if this is the case, you REALLY don't need to even be considering a CarPC at this point
    Jan Bennett
  6. #16
    Mar 2006
    Quote Originally Posted by Red GTi VR6
    Well I knew nothing about cars (I'm a computer guy ), so when I installed mine, I learned a bunch of new stuff. I took my time, and I did it pretty well. Same with my remote start/door locker thing. Never even thought to look under the steering wheel, until I read the book thing. I know, sounds like a n00b, but I still think I am because I don't know much about cars, but this is forcing me to learn. I think with the help of some pictures and a Haynes manual, he'll/she'll be able to figure it out and do it blindfolded the next time (lets hope there's not though!).
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. Replies: 20
    Last Post: 02-09-2006, 03:22 AM
  3. Carputer Shock Absorber
    By bcholagh in forum General MP3Car Discussion
    Last Post: 08-09-2005, 12:09 AM
  4. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  5. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
