Results 1 to 10 of 19
Thread: my carputer... n e suggestions.
    Jun 2006
    ok guys i have come up with this for my car computer....
    Intel Celeron D 2.5GHz
    ASUS P5V800MX MB
    80G 7200rpm HD
    256MB PC3200 DDR
    16xDVD-ROM
    onboard everything
    400 watt power supply
    running with 1 8 inch tv in the front, 2 8 inch sun visors, 1 8 inch drop down.
    also running 2 12 inch subs w/ 500 watt rms amp with cap.
    also adding gps to it w/ i guildance.
    n e suggestions comments will be very helpful.
    Constant Bitrate Eternalodyssey's Avatar
    Oct 2005
    St. Louis, MO
    Are you sure your civic alternator will be able to handle all of those components? I would add all of the amperage up and do a rough comparison. your setup doesn't sound too bed but then again I have a truck alternator that cranks out a good amount of amps for my tow package (trailer) and what not. I don't know what car alternators usually crank out. Just make sure you're not straining it or you might need to go with a bigger alternator.
    Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
    IS JACK BAUER GONNA HAVE TO SMACK A *****?
    Elsewhere
    How do you intend to power it?
    Celeron D's suck a fair bit of power.
    How about the Wiki?
    Jun 2006
    thanks for the suggestions!
    well... ill do what u guys have told me... as for powering it i got a new battery (optima red) for power which i think should hold up. and i will be purchasing an extra power supply what ever u call them... as for altinators i might have to upgrade then... i will check everything out and let u guys kno thanks for the comments
    Elsewhere
    You obviously haven't thought this through yet.
    Check out the FAQ Emporium and do some reading. I recommend reading everything that might even come close to possibly relating to your setup. You can never learn too much.
    How about the Wiki?
    Low Bitrate Tibby93's Avatar
    Apr 2006
    Ottawa, Ontario
    Only thing that comes to mind is OVERKILL with the screens. If you got one up front, why the two visors? Or if you got one fold down I guess for the back, why the sun visors? Or why have the front one with 2 sun visors... When will you ever need 4 screens? If Anything, go one up front with one in each headrest. That's more than plenty.
    And as mentioned, a stereo alone is enough to strain the alternator, throw in a buttload of watts for the computer and then power all those screens. I bet you'll end up with a PS2 or Xbox in there too, and eventually upgrade your door speakers. Power is one of the issues for your car working in the end, and the amount of screens is a secondary, not so important issue, but doesn't make sense to me.
    Teach me.
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    Check my sig. I went with a Celeron M instead of the Celeron D I originaly planned. I am able to use a 90w PSU now. And I even use a 128mb MX440 for the ocasional game that uses 30w of that. Mobo was $60, CPU $25, CPU adapter was $50.
    I see the Pentium M line as the perfect blend of power and efficeincy, finding a middle ground between the desktop CPU's and the VIA's.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    _
    Mar 2004
    Little Elm, Texas
    so....you didn't upgrade anything else other than the battery?
    JUST upgrading your battery won't be enough, afterall, if your alternator can't keep up and charge the battery all while providing power to the rest of your car while running, what good is your battery then?
    what's the rating on the stock alternator?
    yet again, it sounds to me more like someone wanting an extension for their geek penis....WAYYY over kill
    why in the hell do you need a screen in the front, a drop down screen AND screens in the visors?
    leme guys, you're the guy that rides around with all the screens on when you're the ONLY one in the car....
    Jan Bennett
    Apr 2006
    Ottawa, Ontario
    Teach me.
    Jun 2006
    what kind of alternator would u guys reccomend? lemme kno thanks! and would u reccomend getting 2 batteries or caps... as for the computer ive thought it through and yes the petium M is better and i will upgrade that... thanks for all the help... lemme kno if u have n e other comments suggestions this is a great board thanks everyone! lol and no im not the only one in the ride when there turned one lol... i have more self respect than to do that lol... ive over time done a lot to the car not a one shot bang im done kinda thing lol... its been a step by step prosess!
  1. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  2. Replies: 2
    Last Post: 07-30-2005, 09:25 AM
  3. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  4. Replies: 9
    Last Post: 10-23-2004, 03:25 AM
  5. Carputer in '03 Vette - plz suggest
    By slushieken in forum Newbie
    Last Post: 04-19-2004, 12:15 PM
