Results 1 to 10 of 10
Thread: Looking for further direction
    Jun 2006
    I’m looking for input on how to go about getting what I’m looking for in use and features. I’m guessing from what I have read that yes, I can do it, but I’m hoping for some experienced people to give me some free advice and perhaps a nudge in the right direction. I want to drop my work laptop into a docking station or something along those lines in my van, and I want that station hooked up to a LCD touch screen and the car sound system.
    I’m thinking I need the following…
    1) Laptop, which I already have. ( I’m guessing buying and using a docking station would be advisable, IBM Thinkpad T43)
    2) Power Supply, I have one that plugs into the cigarette lighter, also an inverter that would allow me to use a wall plug adapter. I would like to know how to hardwire this into my car, I would need detailed instructions though since I have zero experience with wiring and such. Perhaps there is a write up or FAQ I haven’t found?
    3) Touchscreen LCD and perhaps a small keyboard and mouse. On the keyboard and mouse I’m not sure what to do. I read that USB stuff doesn’t always like to “wake up” so serial is better, but my laptop (IBM Thinkpad T43) doesn’t even have a serial port.
    I should be able to hook up the display to the laptop docking station but the cords that come with them don’t appear to be near long enough. I would like to mount the docking station, under or alongside the driver seaat. I own a 2005 Dodge Grand Caravan. Can I buy or make extension cords for that purpose? Are there instructions for such a thing in the FAQ or somewhere else?
    Thanks for any help or input.
    May 2006
    Perth, Australia
    Don't use the Inverter with the AC adapter. It's unnecessarily converting from DC to AC to DC again. Use the DC-DC adapter. All yo'ud need to do to hardwire it is wire it to the distribution block where your cigarette ligher is plugged into.
    Serial keyboards don't exist.
    Serial Mice are actually quite a pain. You have to have them plugged in before the computer startrs from a cold boot. Surely you're docking station will have a PS/2 connector, and from that you could get a PS/2 Y splitter cable, and connect a PS/2 mouse and keyboard. PS/2 do not have any "wake-up" issues as far as my knowledge goes.
    If the docking station has a VGA out, theny by all means you can connect the display to it. A touchscreen will take up a USB port also, for interface.
    If you're unaware that VGA extension cables exist, you don't have have a chance in hell at being able to make your own.
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Un_discovered
    I was under the impression that quite often the PS/2 ports were often referred to as serial ports, at least in the past.
    this all goes back to the fact that this guy needs to do a LOT more research...rather than posting up pretty much the same questions as he did in another thread already....lol
    Jan Bennett
    May 2006
    Perth, Australia
    Red:
    A serial port is the 9 pin connector:
    A PS/2 port however:
    Yeah, as I said in the other thread :P
    And yes, he does need to do a lot more research. A LOT.
    As I said previously:
    A person unaware of that, should really be looking into a different hobby.
    _
    Mar 2004
    Little Elm, Texas
    I'm aware of the differences, I think you missed the point of my post...
    in the past, many times, they were BOTH called serial ports....I'll see if I can't find it in a text book I have at home....because when I read it in there it really threw me off at first, until I realized that it was a long time ago that it was written....
    Jan Bennett
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Red:
    Not exactly. That DB9 connector and PS2 connector are both serial ports. The 9-pin is RS232 while the other is PS/2, but each is a serial protocol.
    But why is this question being asked? The OP could have easily searched for the answer. The answer is, yes, you can make extensions. Connect pin1 to pin1, pin2 to pin2, etc.. A simple null extension.
    Yes, or read computers for dummies.
    May 2006
    Perth, Australia
    Oh, my apologies.
    Really?
    Wow, I've never heard of the PS/2 ports being reffered to as Serial ports, that's really odd o.O
    EDIT: Bad post timing.
    Okay, thanks TheLlama, was unaware of that.
    Elsewhere
    The PS/2 is a serial connection with specialized use.
    USB is also a serial connection, although capable of higher speeds than a serial port.
    The differences are in how the motherboard chipsets handle the communications on the various types of ports.
    How about the Wiki?
    May 2006
    Perth, Australia
    Okay.
    Still learning then, .
    But aren't we all? :P
    Oct 2004
    NY
    Quote Originally Posted by TheLlama
    ...add shielding after the cable is done by wrapping it in foil after running an exposed wire along the new harness, & then ground the exposed(drain) wire on both ends....
    either that, or just buy one at staples
  1. Problem with DIRECTION indicator
    By Passe in forum Road Runner
    Last Post: 06-10-2006, 02:27 AM
  2. Arrows on videos in direction of motion!
    By doof205 in forum Software & Software Development
    Last Post: 11-16-2005, 03:16 PM
  3. Direction Indicator for MM & FD
    By GizmoQ in forum RR Skins
    Last Post: 10-10-2005, 12:50 AM
  4. Replies: 5
    Last Post: 10-05-2005, 11:34 AM
  5. Direction Sensing Active IR Sensor Thing.
    By Mio in forum Hardware Development
    Last Post: 10-03-2005, 12:55 AM
