Results 1 to 6 of 6
Thread: Some help please
    Jun 2006
    Talking Some help please
    Hi im looking at doing my very first carputer but i still had some questions
    1. is it worth putting in a psu that has a start up with iginition
    2. would it be smart to keep my head unit or is it just easier to use the carputer for everything
    3. cause i live in australia i need a front end for the touch screen something with gps but im not sure how the front end work with the gps
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    1. That's up to you, and whether or not you want the computer to start up and shut down automatically when you get in the car.
    2. Again up to you depending on what you want to do, and can afford.
    3. Do some light reading in the FAQs
    _
    Mar 2004
    Little Elm, Texas
    "We can't help you unless you can help yourself"
    hehe
    I'm going to start using that in all of the threads...lol
    the answer to the first two questions is that it's 100% up to you, you need to read up on the pros and cons of both and decide which fits your needs best
    and what does living in australia have to do with needing a front end?
    Jan Bennett
    May 2005
    Conyers, GA
    Quote Originally Posted by Red GTi VR6
    Maybe they need it vertically flipped? Upside-down?
    _
    Mar 2004
    Little Elm, Texas
    hahahaha
    good one
    Jan Bennett
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    lol red . thats awesome.
    as far as front ends, think of them as gui for touchscreen. for functionality try each one out and see what you like. you can download them in the software section.
    For GPS. the software is standalone. and then you integrate it into the front end. you might want to look in the gps section to see what software is best for australia. and go with that one. most gps software is in the range of 100 bucks. youll also need a gps reciever that will run you somewhere around 80 or so.
    as far as keeping your headunit. the only reason would be for radio quality. when building your system you can go with an audigy or onboard sound and have no problem outputting to your amps and speakers. theres hardware out there for fm radio; hauppage, radiator, etc., I would suggest staying away from those the quality of them sucks for the most part. if you get rid of your headunit and still want radio i suggest you looking into HQCT. it was designed specifically for computers in cars.
    Everything depends on how much money you want to spend, how much time you want to involve in getting everything to work, and what exactly you decide to do. To be honest with you knowledge is the key. what money you have to spend on this hobbie will decide how quick it gets done or how nice, but without knowledge nothing happens.
    Spend a few weeks reading thru the forums. ask yourself questions, and then search some more. and then those questiuons will lead to more answers yet still more questions. when you feel like you have a handle on what your about to do, then start to buy stuff based off your research and new found knowledge.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
