Results 1 to 8 of 8
Thread: Will a Xenarc power on with just power from USB?
    May 2006
    Calgary, Alberta
    For fear of flamage, I posted this in the Newbie section because I think it's kind of dumb. However I did search to see if anyone else asked it.
    I have a Xenarc screen and it won't turn on unless I plug it in somewhere, either to a cigarette adapter or the wall. Isn't it supposed to just run off the computer's PSU via USB? Head scratcher.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    the usb that comes out of it is just for the touch screen. you can pull power from a usb but thats only 5v. your monitor takes 12v. I would suggest taking the cord that is meant to plug into the cigerette lighter, and wiring it into a molex connector. (the four wire connector that plugs into a hd for power) the molex has 4 wires. (5v gnd gnd 12v) look online for which wire is which.you should have an open molex coming from the ps. if not, you can get a Y adaopter to take 1 molex and make it two,.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    Oct 2004
    NY
    no, the usb power provides power for the touchscreen only, the lcd & backlight assembly needs much more power than can be provided by usb, not to mention it needs 12v instead of usb's 5v..
    May 2006
    Calgary, Alberta
    Ya, there's loads of FAQ in the screen section, not sure why they didn't turn up in the search. Case closed. Thanks, guys!
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    I'm going to ground it in the dash and power it through the fuse panel via the radio slot. This'll be easier than trying to run the wire to the trunk and then somehow getting it inside the computer case.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    _
    Mar 2004
    Little Elm, Texas
    keep in mind that in running the screen directly off of the cars power you aren't getting the cleanest signal possible. This may not even be an issue for you, you'll never know till you try it out.
    If you end up having lines across your screen and the image isn't all that clear, you might consider running the power off of the computer PSU. These PSUs basically filter the electricity that goes into them and spits out a much cleaner signal.
    Hope this helps.
    Jan Bennett
    May 2006
    Calgary, Alberta
    Hmmm, maybe I'll pick up a molex tonight. Thanks. I just wanted to eliminate wires running to the back of the car, I can only fit so much under the panels!
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Like Red said, you have to be carefull hook up directly to the car power cuz it is vary from 8 to 15 or more/less volts.
    If the Xernac has a "regulator" like the Lilliput's Egg, it's okay to run directly from the car power (aka cig lighter/adapter). If it doesn't have a regulator, hook it to the PSU 12V rail => Yellow + and Black - on the HD molex.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 02:05 PM
  3. power requirements for 2 USB hubs (urgent)
    By ramy_zohair in forum General Hardware Discussion
    Last Post: 11-11-2005, 08:27 AM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 02:50 AM
