I guess I'm a little lost as to what you are asking here with your post?
Hi
i often take my laptop (hp nx9105) in the car with me... but getting new car (passat) sept 2nd and want to build a pc into it, i guess i could just buy bits and see how i get on but i'd rather seek adviceand get it right first time
Steve
i'm after good run time when engine isn't running
wireless access
permenant net connection, gprs??
gps, with mappoint 2006 europe
music
video
tv
would prefer in dash motor touch screen
got this type of dash with out cd
2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
Jan Bennett
i need to know what to buy lol...
Thanks for posting in the Newbie section. We know this is a tough hobby to get into but you really have to do at least a little bit of reading before you post here. Please check out some of the FAQs or use the search features of the forum. You will find people much more willing to help you if you have put a bit more thought into your question
ok
i'll just start buying stuff then![]()
He's right. You landed on the right forum, there's plenty of information to go through. Take your time to read at least the FAQs, they're worth your time.
Project BioHazardous Material || BioHazard . LU
████████████████░░░░ CAR
████████████░░░░░░░░ LAPTOP
█████████████░░░░░░░ FRONT-END SKIN
██████████████░░░░░░ PERIPHERALS
░░░░░░░░░░░░░░░░░░░░ INTEGRATION
It makes many answers to your questions magically appear. Just cruise around the different forums and get an idea of what everyone similar is doing and then consider what you might do to make the project all your own.
Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
IS JACK BAUER GONNA HAVE TO SMACK A *****?
Steve, while most of your post is generic stuff you can search for you also mention you want a good run time with the engine off. For this use you may want to consider looking into tank batteries with split charge systems. There will be a lot of info on here but I don't know if there are any FAQs for them.
i think i have the split charge sorted gonna use a big deep cycle battery and a towing relay
Self-Switching Combination Relay
H78
The self-switching combination relay is straightforward to fit and supplies power to the caravan's +12v, battery charging and refrigerator supplies only when the vehicles engine is running and the alternator is providing enough output. It automatically prioritises charging of the vehicle battery over all other functions, and requires no connection into the vehicle's alternator or ECU wiring
and a Leisure Battery (110 AMP)
ok been searching...
sorted the power feeds as above
now power supply
220w should cover everything?
MPEGBOX DSATX 220W DC-DC ATX Automotive
