Results 1 to 9 of 9
Thread: Important CarPC Power question
    Jun 2006
    I have purchased myself a new CarPC its power pack transforms 110v to 12v 4500mA
    and...
    240v to 19v 2950mA
    now if i hookup this carpc strait to my car battery (without putting it through it power pack/transformer) which puts out appx 12.9v at 15-20 A will it be fine or will the amps be to much for it
    Newbie FelonyJake's Avatar
    Apr 2005
    UpState NY
    im a tad new at this but it sounds like it should work
    but i would fuse that bad boy. with a 5 amp fuse or something.
    Raw Wave lostreception's Avatar
    NY
    might i say your username is quite accurate...
    please read the FAQS and no dont do it the 12v is unregulated and will Blow the sensitive computer components
    search b4 u do then search again or else your username might be part of your future for sure
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Apr 2005
    UpState NY
    so thats the point of the dc-dc converter...is to regulate it?
    NY
    Quote Originally Posted by FelonyJake
    yes otherwise you have voltage spikes when u start your car etc
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Jun 2006
    i searched the faqs and there was nothing specifc to what i want to do they all talk about wanting to have use pcs that have 110v or 240v psu's where mine has 12-19v psu
    Apr 2005
    UpState NY
    what he ment was that you dont have to use the transformer you have. (well really you cant without a inverter.) but if you are going to power it from your 12v car bat. that you should use a DC-DC converter. and there is plenty of info of them in the FAQ. and at the mp3car store.
    _
    Mar 2004
    Little Elm, Texas
    I must say that I'm dumbfounded.
    Why would you tell someone "sure, why not!" when you have absolutely no idea what you are talking about?
    Jan Bennett
    Low Bitrate MrGee's Avatar
    Jun 2006
    Toronto, Canada
    FAQ: Power Supplies Explained (Part 1)
    Even more important
    Battery --> Regulator --> startup/shutdown controller --> Power supply --> Computer
    That thread should help...
    Most power supplies listed in the sites store and what not have built in Regulators and startup/shutdown controllers and are power supplies...
  1. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  2. power supply question?
    By pimpmode in forum Power Supplies
    Last Post: 03-23-2005, 05:42 PM
  3. Noob question about power supplies
    By Jagojon3 in forum Newbie
    Last Post: 03-09-2005, 12:35 AM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. temporary carpc, will this power setup work?
    By bobthebaker in forum Power Supplies
    Last Post: 10-11-2004, 04:21 PM
