Results 1 to 6 of 6
Thread: Various questions about CarPC in a 2006 Ford Focus
    Mar 2006
    I've been trying to do as much research as possible, and now I have a few questions.
    My dashboard is identical to this:
    I'd like to avoid moving the A/C controls and the DC outlet if possible, especially the A/C controls. I'm thinking removing the radio and replacing it with a 7" Touchscreen LCD. Would I have enough room to put a 7" LCD and a slim DVD drive under/above it? Would the DVD drive have to be an external USB drive in order to put it in the dashboard? If a DVD in the dash isn't an option, where is convenient another place it could be put?
    I've looked to see if any people had put CarPCs in Ford Focuses newer than '03, since they changed the dashboard, but I haven't seen a single one.
    Looking for advice.
    Thanks.
    Newbie Brad Groux's Avatar
    Jun 2006
    Houston, TX
    That looks really similar and probably the exact same size as the new F150 and Mustang radio units... do some searches for 2005 or 2006 Mustangs builds here, there are some great and relatively easy builds for it like THIS ONE.
    CarPC for 2006 Land Rover LR3
    [++++++++++] 0% Complete
    {o,o}
    |)__)
    O RLY?
    _
    Mar 2004
    Little Elm, Texas
    take measurements of the area you have to work with, and compare those measurements to the different screens avaliable
    Jan Bennett
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    it looks like you can fit a 7" no problem where the radio is. if you want a slim line at the same place youll probably have to relocate or remove the lcd buttons.
    just my .02 from what i see.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    You havent seen one? Psssh..
    The "You AND Your Install" Pic Thread
    That is mine. A 2005 Ford Focus ZX3.
    You should just get the dimensions of your LCD (including case) and slot load DVD and measure your dash.
    Assuming it wont fit w/o some moderate modification (which I believe) I would put the dvd in one of two places:
    1) There is a CD holder down and to the left of the steering wheel, it actually covers the fuse box
    2) There is a misc items holder below the grey bezel, but it might be too small.
    Or you could put it in your glovebox... but then you'd have no where to put your mittens
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Sep 2005
    Seattle, WA
    PS I dont have a DVD drive... I dont see a purpose other than installing the OS ( I hooked my desktop's internal DVD rom to the PC for that )
    B Smoov
  1. Ford Galaxy Ghia - CarPC project
    By Needstorage in forum Show off your project
    Last Post: 04-10-2006, 07:54 AM
  2. Start my own carpc build (have a few questions).
    By 1st time modder in forum Newbie
    Last Post: 01-10-2005, 07:11 PM
  3. Carputer SQ questions...
    By tweek in forum Newbie
    Last Post: 08-11-2004, 05:27 AM
  4. 3 Sound related questions for CarPC
    By nirvanades in forum General Hardware Discussion
    Last Post: 05-31-2004, 09:04 AM
  5. New to CarPC I have lots of questions
    By FreeFlyr in forum Newbie
    Last Post: 05-11-2004, 07:07 PM
