Results 1 to 10 of 16
Thread: Radio faceplate relocation - interference?
    Jan 2006
    Cyprus
    Just finished my BMW E46 carputer project and the last thing I have to do is move the radio faceplate from the trunk to the space near the handbrake.
    Due to lack of space, I had to relocate the aftermarket radio on the back, next to the carputer and then I planed to move the radio faceplate only in front.
    For this, Instead of using cat5 I used high quality shielded computer cable, for greater insulation. The problem is that the radio refuses to work when the wires are more than 1m in length, possibly due to interference? How can I overcome this?
    Any help greately appreciated!
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Do you have the shield(s) of the cable(s) grounded?
    Also, it's quite possible that it's an issue of voltage drop/signal degradation on the wires, than an interference issue. to test it, you could try using the faceplate on long wires but having it outside of the car (cable leading out of the trunk, etc) where it should not be getting much external interference.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by paris
    ...Instead of using cat5 I used high quality shielded computer cable, for greater insulation...
    Why?
    I'd figure cat5 would have the least amount of resistance, which would let you run a longer distance. Could always get some shielded cat5.
    What the hell is high quality shielded computer cable anyway?
    Tidder
    Try RevFE
    Jan 2006
    Cyprus
    Here's how it goes:
    2 shielded cables each containing 8 wires go from trunk to handbrake space.
    starting from the tuner part in the trunk, 15 wires are soldered on the PCB in the tuner, then end in a male parallel port. there they connect with the wires soldered on a female parallel port which go below carpeting until the handbrake where another parallel port is connected. then another parallel port male this time, is used to connect the faceplate with the rest of the wires. The wires are also soldered on the pcb inside the faceplate. It's like having 2 connections. in order to be able to remove the tuner and the radio and at the same time leaving unaffected the cabling under the carpets.
    I'll ground the shielding to see if any good. I assume I must ground every single shielding, i.e. where the parallel port connections are, correct?
    Sep 2003
    New Mexico, USA
    Yeah, it's good to have all your shielding grounded.
    It still sounds to me though that your cable is dropping the signal quite bad, which leads me to think it's crap. I did this with an old Pioneer deck, and ran unshielded cat5 about 9ft which worked ok.
    Tidder
    Try RevFE
    Jan 2006
    Cyprus
    I'll ground the shields and see how it goes.
    This cable is thicker than cat5, due to thicker insulation and heavier shielding. 8 wires in it in twisted pairs just like cat 5, only that each wire, is composed of many copper lines, not a single line like cat5.
    It's even more expensive, $4.00 per meter..
    Sep 2003
    New Mexico, USA
    And it could always be that your HU is just not putting out enough juice to power it's face that far away.
    Tidder
    Try RevFE
    Jan 2006
    Cyprus
    the cable is 3m in length. I'll give it a try using UTP or STP and post the results.. thanks
    Sep 2003
    New Mexico, USA
    Sounds good. You got a link to the type of cable you bought?
    Tidder
    Try RevFE
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    yeah from what i just read it sounds like your getting a dropped signal and its not making it to the HU. as posted, try better cable. for 3m of cable, you would think you should have enough voltage, but it might be really low power since the face plate was designed to be right on the connections.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  1. FAQ: EMI / RF Interference
    By aoLhaTer in forum The FAQ Emporium
    Last Post: 02-05-2008, 12:44 PM
  2. Remote faceplate! turned out really nice, check it out
    By Sporttracguy in forum Car Audio
    Last Post: 02-23-2007, 02:07 AM
  3. 6th gen accord radio relocation go or no go?
    By total-assault in forum Car Audio
    Last Post: 06-26-2006, 04:58 PM
  4. TM-701L converted Lilliput causes radio interference
    By archimense in forum LCD/Display
    Last Post: 07-04-2004, 09:14 AM
  5. Fm Radio
    By vicky_obee in forum Media Engine
    Last Post: 07-01-2004, 11:52 PM
