Results 1 to 8 of 8
Thread: Buy Case Or Build Case
    Jul 2006
    Las Vegas
    Not sure how to search for this, tried a few different strings and found nothing. Basicall I'm wondering if I should save 90$ on a case... and use the money to buy the materials, fans, and build a case.
    On another side, not thinking of money, but of performance. Now I live in Las Vegas, so my trunk is going to be hotter than hell and there is not a single feasible way to change that. Now I wonder if I would benefit more from making an enclosed case, buying an enclosed case, or building some open aired case.
    Feb 2004
    North Aurora, IL
    Quote Originally Posted by setite
    i have built a case and bought a case (shuttle). Honestly speaking.. i like the case i made out of an old aluminum star trek game. Its got better ventilation, and cross ventilation. It does a lot better job than my shuttle case done in terms of keeping heat down. but if your good with a dremel or other tools (i wasnt, it was a learning expierience for me)... and have the time id say build a case that fits ur custom needs.
    i have to say that the case i made is ugly as hell though... but it gets the job done and is stuck in the trunk so no one sees it
    I wish i knew how to do fiberglass work...
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Build it yourself.
    The main reason is build it to the exact size that fit to where you gona put it. That way, you can maximize the size to get better ventilation/airspace ... well you know ...
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    _
    Mar 2004
    Little Elm, Texas
    no case?
    I'm not running a case. (click the below pic for a larger pic)
    More pics: http://www.mj-garage.com/cpg/display...album=12&pos=3
    It's been 105 or so here in the DF/W area for a week +. Every day when I come out of work, my car temp gauge reads at 111+. I've yet to have a single problem with the computer. It's booted up and been playing music flawlessly for over a year now. It probably gets more air flow like this than most CarPC designed cases.
    Jan Bennett
    Jul 2006
    Las Vegas
    so with 110-120 degree temperatures you think an open aired solution will be fine... does yours have any fans? mines going to be a smidgeon hotter than yours i figure because of the temps here in vegas and because its an amd athlon 64 3000+ but im not worried now about that as much as i am about powering it... cant figure out how im going to power it
    need to figure out what my power specs will be
    _
    Mar 2004
    Little Elm, Texas
    I'm only using hte onboard fan that's on the processor, that's it.
    with that processor, you might consider running a bigger fan on it than the equivilant to what I'm running....I've yet to have any problems though!
    Jan Bennett
    Variable Bitrate red_parchel's Avatar
    Jul 2006
    Boston, Ma
    I've asked my self the same question, from what i've done w/ my car, i think it depends on where you want the computer, if you're tight on space make it, if you've got all the room in the world [when does that EVER happen?] save the trouble and buy one .. but if ya can make a case and have the time .. go for it!
    props to ya
    MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
    --worklog--
    Jun 2006
    i actually bought a case and im really happy with it actually... might be a little big but i think its gonna work out just great ... its the aopen G325... good case...
  1. Does anyone want to build a fiberglass mold?
    By SecretSpyder in forum Fabrication
    Last Post: 11-09-2007, 05:10 PM
  2. Remove my pc guts and put into smaller case
    By muldrick in forum General Hardware Discussion
    Last Post: 09-03-2006, 09:12 PM
  3. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  4. Mini-ITX case troubles.
    By Rickles in forum General MP3Car Discussion
    Last Post: 06-21-2005, 06:20 PM
  5. Building a new case for my BookPC
    By Phacade GSX in forum General Hardware Discussion
    Last Post: 07-29-2000, 06:51 PM
