Results 1 to 10 of 14
Thread: nebie car pc q's
    Newbie lime's Avatar
    Jul 2006
    scarborough, Ontario
    newbie car pc q's
    hey all
    i am currently in the process of putting together my first car p.c
    so far i have gathered these parts
    Mini ITX VIA EPIA MII12000 Motherboard w/ Nemeiah 1 GHZ built in processor
    VOOM PC Car PC case
    256 MB SD Ram ( maybe not enough)
    M2-ATX CAR PC power supply
    Black Mat****a DVD-RW
    7' lilliput in dash single din touch screen. (in the next week or so)
    and my dilema or question is this
    i would like to add wirless internet and gps to complete the package.
    but have no idea which ones will work best with the parts i currently have.
    i will mainly use it for the gps and music ( obdII later on )
    also the touch screen has an fm tuner built in so could i still listen to the radio or will i need a deck also.
    any recomendations or suggestions would be much appreciated.
    thanks for any help or advice you can give.
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    search :T
    any wireless will work (external antenna would get you best reception, but a lot of people dont go external and still get good reception)
    any gps will work, mind you a lot of people recommend the BU-353 (newest one, as i understand anyway)
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    not only do you need a gps antenna you will need map software. you have a few choices out there, but what i would suggest is you try out the different front end softwares available. then depending on which one you like, go with the best map program for that software. I use road runner with iguidance software. Street deck you can buy now from the store and it is a front end/gps program in 1.
    As far as wifi. I use a wireless USB dongle. works fine.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    _
    Mar 2004
    Little Elm, Texas
    FM built into your touch screen?
    I'm guessing that it will just use the built in speaker to reproduce the sound?
    if so, that's going to be poor quality for sure and not very loud.
    Does it have any way to hook up to your PC and channel the sound through a PC?
    Jan Bennett
    Jul 2006
    the one i'm looking at is the 7' lilliput single din motorized touch screen from the store.( 469)
    i was thinking i could hook it up to the audio for my car speakers.( as if i never had the car pc)
    so the music will go from my cpu through the lilliput and then out to the speakers.
    please don't laugh if this doesn't make sense.
    this is the unit i would like to use
    http://store.mp3car.com/SearchResults.asp?Cat=61
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Red GTi VR6
    No its probably a motorized lilli thing, that looks like a HU when closed and plays AM/FM radio. It outputs either in RCA like a HU I believe. Then you will need some audio switcher to switch between radio and PC. Or do a temp hack job (Red is gonna like this one! ) use an inverse RCA splitter to take 2 RCA inputs into 1 and play only 1 at a time. That option, will introduce noise and is not a good fix, but it works.
    I think he wants to use it as a backup so independant of PC incase it blows up or something!
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2006
    Quote Originally Posted by 2k1Toaster
    so if i buy a deck and hook the lilliput's monitor up to the aux input for the deck i should need no switch and then get sound from the car speakers.
    from what i have read is this the way most go?
    Jul 2006
    ok i've got one more question.
    my 7" lilliput motorized touch screen has a hook up on the back to run it like a head unit. ( power ground all 4 speakers)
    so if i hook up the stock wiring to the screen then switch to vga mode for the cpu,( the vga lead has 2 rca's as well, these i will plug into the sound on my pc.)
    this is what the bcak of the lilliput looks like
    the harness plugs into the white plug and then into the car audio
    will the sound go through the speakers when the lilliput is in vga mode.
    here is the harness for the vga
    the reason i am asking is because there don't seem to be any built in speakers on the lilliput.
    thanks again for all your help
    Newbie Benny111111's Avatar
    Jul 2006
    Australia
    I'm only new to this but i thought why don't u take the outputs from your screen and feed them into your microphone/line in input on your mother board.
    That way you will be able to control the volume and mute the microphone on the mother board.
    Saves stuffing around with switches and hacking things.
    It's easier taking things apart !!!
    Sep 2005
    Dude check out my worklog on MO.com...and read through it. feel free to PM me to ask questions, my AIM name is in my profile on MO.
    -Mike
  1. A Bodgy Car PC.
    By Bodgy in forum Show off your project
    Last Post: 02-05-2007, 11:58 PM
  2. First install of car pc working :)
    By optip in forum General Hardware Discussion
    Last Post: 09-09-2006, 08:13 PM
  3. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  4. Car PC in Seat Ibiza.
    By onlineamiga in forum Show off your project
    Last Post: 12-25-2005, 07:44 PM
