I've installed a car amp once with everything and all, but I think this is al you need. For de switch just look on ebay or so for a audio switch. Don't know exactly what you need but I think there are some around. Good luck
Hi,
I'm thinking of installing an amp in my crappy corsa. It's not to get banging tunes or anything but simply to have the choice of plugging in an AUX device (stock radio has no aux).
I know i have the option of upgrading the radio but was thinking about an amp because one day in the future i might want to add a computer to my car but for now i just need an aux input.
So i have a 4 speaker car (stock speakers), 2 front, 2 rear.
I have a couple of days of so was going to go and buy this amp
http://www.maplin.co.uk/Module.aspx?...20Amps&doy=3m8
because it's the cheapest one i could buy in a shop today.
I was also going to buy this wiring kit
http://www.maplin.co.uk/Search.aspx?...=L82AK&DOY=3m8
Since i am new to this could someone have a look at the wiring kit and tell me if it has everything needed for a basic install.
My other question is how do i split the input to the amp with a switch so i can flick between radio and aux device.
Cheers.
Jon
Car: Peugeot 106
Monitor: K500
Carputer: Acer Travelmate 661Lmi
Front-end: RoadRunner
Skin: Simplistique by LLOYDY
Navigation: iGuidance 2.1.2 Europe, embedded with iGlaunch
GPS: BU-353 USB
▬▬▬30%▬▬▬▬▬▬▬
It's not 100% necessary but if you use a LOC (line Output Converter) to convert your inputs from the factory wiring to RCA's you will get much better sound. Also if you are going to do it that way you will need another set of RCA's or "5m twin phono interconnect lead" as they are called on that page. Hope this made sense.
Yeah that was going to be my next question. I'm looking at the back of my radio and hope i'm right in thinking that the output from here that goes to the amp would be from the speaker pins. (4 speakers - 8 pins).Originally Posted by MECP Buddah
So that means i'd have to convert this to RCA's using a LOC.
So the setup would be Radio - LOC - Amp - Speakers in basic terms.
Am i right in thinking this ?
I looked around google and there are a few types of LOCs. Would i need more than 1? Can someone point me in the right direction with this.
Thanks for the help.
Jon
there are several types of LOC's some are for 2 channels some are for 4 you could either do 2 two channel LOC's 1 four channel LOC and keep all of your fade and balance controls etc or you could get away with using 1 2 channel LOC and a pair of stereo splitters to get all four inputs for the amp, however you will lose some control over the sound (usually balance)
Friends don't let friends install car audio.
