Results 1 to 10 of 18
Thread: Hello, a simple question
    Aug 2006
    Thumbs up Hello, a simple question
    Hi,
    New to car PC and I'm loving this forum.
    I've been in IT for 18 years and I've installed 13 kick a$$ car stereo so I'm hoping I can pull this one off, I'm getting older and squeezing into some of those tight spots in cars to do installs is starting to hurt a little heh heh.
    I have a question about batteries and a project like this. I've read in some of the threads and faqs that you can either connect the touch screen to computer power supply or straight to the battery. I can't find a discussion on pros and cons of each. At the very least I think I'd need some sort of surge protection if go straight to the battery.
    second, do these car PCs act like laptops so that when you kill the engine they run on battery for a little bit then go to sleep or do they just get killed hard. Not sure about this one as I can't find it on this site.
    Best Regards,
    oh, I have a 2000 4runner decked out for 4wheelin' and a pretty kickin system, but now the Alpine 7878 has melted its motherboard, I need a new solution.
    http://www.reapur.com
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    no questions are simple.
    some screens can be powered straight from the battery. however, many people feel that if they spend $300+ on a nice screen, they should invest in a regulated power supply.
    many power supplies have shutdown controllers, meaning they shut down automatically when the car is off.
    this are common questions for a newbie. read the Frequently Asked Questions, specifically the ones on power supplies.
    good luck
    _
    Mar 2004
    Little Elm, Texas
    read up regarding just what the power supplies do. Many of them have integrated start-up and shut down controllers.
    Some people go into stand-by, some hibernate, and others just shut down completely.
    It's your decision which you should do.
    As for the screen, that's your decision as well.
    Some run direct off the battery (myself) others don't.
    Personal preferences.
    Jan Bennett
    Aug 2006
    Thanks Guys.
    I actually just found the faq to the faqs, I don't know how I missed it, I've been reading here for a week... Sometimes gotta pull your head out to see clearly
    cheers
    _
    Mar 2004
    Little Elm, Texas
    glad ya found it!
    There is a lot of information on this board. It's quite easy to get lost in it all!
    Jan Bennett
    Aug 2006
    OK, another point I can't seem to nail down:
    If I have a complete car stereo with HU, amps and all that. If I were to add a carPC (I'm almost done picking my parts) I'm not very clear on the interaction between the carpc/touchscreen and the HU.
    I have an alpine HU, and I'm thinking about the DWW flipout screen, that way I use up my double-DIN.
    I understand how the carpc connects to the amps and all that when the HU is nto present, but I can't find a diagram or an explanation of how I would switch to the HU to play a CD or FM, then switch to the PC to play a video or navigation. Can they be used at the same time (CD and navigation?)
    pardon me if these are lame questions, but I'm not getting this part.
    best regards
    Elsewhere
    If you're going to retain a headunit, then the easiest method for audio is to run the PC's audio into the aux in of the headunit (assuming you have one!).
    If you want to hear GPS prompts and play a CD at the same time, you're going to be playing the CD throught he PC or have an additional audio device and speaker(s) specifically for the navigational prompts.
    Welcome to our madness.
    How about the Wiki?
    Aug 2006
    Thanks for confirming what I was thinking. I don't see another way about this, unless I get a labtec speaker hidden behind the dash for the PC sound, but that wouldn't be good.
    Maybe I'll just dump the HU, since it only really works in the winter, and go with a full carpc solution.
    I wish I had a store in town that carried some of this stuff so that I can "feel" how the system will fit in my truck.
    aaaaaahhhhhhhhh, madness ineed!
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    Well.... I have a question: Why cant you have a multi-channel soundcard, and select your GPS Nav program to only spit out audio to one channel, which would be an aditional speaker somewhere in the car, while your HU is on.... Wouldnt that work aswell?
    Personally, I cant see the advantage to having a HU plus a Carputer except for the FM Radio aspect of it. (which can be solved with a FM Tuner Card) But thats just my opinion of course....
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by we87 View Post
    That and a backup. All CarPC's will go crazy sometime, and usually in the middle of some 7000hour cross country trip. So, a backup.
    Also since he is going with a flip out, why not get a flip out that has built in radio/cd. Backup built in, and it'll look cleaner while solving the dillema of getting both sounds!
    1.9in x 2.9in -- 47mm x 73mm
  1. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 11:07 AM
  2. Complete Newbie Question.
    By DomesticImport in forum Newbie
    Last Post: 07-07-2005, 07:24 PM
  3. simple lilliput ribbons question
    By avidan in forum LCD/Display
    Last Post: 01-27-2005, 09:28 PM
  4. Simple Wiring Question
    By ukchris in forum LCD/Display
    Last Post: 12-30-2004, 01:43 AM
  5. simple question - cd changer control
    By tbone in forum General Hardware Discussion
    Last Post: 09-09-2001, 08:51 PM
