Results 1 to 4 of 4
Thread: FM Radio on carputer?
    Aug 2006
    Hi,
    I've been going thru the faqs and I'm having a hard time finding information on how FM radio works.
    I really can't find the info on this.
    Is there a faq I missed? Say I build a carputer, how then do I get to listen to FM and AM? I do not want Sat radio.
    Cheers
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Quote Originally Posted by reapur View Post
    Hi,
    Cheers
    Theres a free program called radiator... check that out.
    Also if u achieve your FM functionality trough TV-card, u could check out winamps tv-plugin, im not too sure how FM operates in roadrunner, but since it uses winamp, this would sound like logical choige...
    _
    Mar 2004
    Little Elm, Texas
    Search for 'HQCT'
    Should get you going.
    Jan Bennett
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    you either keep a head unit to listen to fm, and input the pc into the aux port on it, or you go with a hqct, radiator, wintv with fm. etc. so far the best ive found is the hqct. Its almost as good as a head unit but not quite there yet.,
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 10:56 AM
  2. FAQ: Installing XM Radio on Your Carputer, a Tutorial
    By Bugbyte in forum The FAQ Emporium
    Last Post: 03-14-2008, 01:36 AM
  3. FM radio in your carputer
    By Boarderx192 in forum Newbie
    Last Post: 06-03-2005, 04:11 PM
  4. D-Link USB FM Radio
    By Kalle.se in forum General Hardware Discussion
    Last Post: 09-15-2004, 04:24 AM
