utilize the resources that are available to you: FAQ: Determining proper gauge wire/fuse size/battery size/alternator size
just a quick one i got 2 x 1500watt amps(2channal) with a 3000watt amp wiring kit (4ga 80a fuse)
i want to use a distro block with fuses and go from one 4ga to 2 x 8ga what size fuses for the distro block(8ga)?
40amps makes sence to me
Jan Bennett
cheers RED
going by that i can go max 50amp for 8ga i think im gonna use 40a for now see how it goes
again cheers Red
:d
Jan Bennett
