Results 1 to 10 of 13
Thread: Initial Trades: Laptop vs. Motherboard
    Aug 2005
    Hello All,
    I've been snooping around this site for about a year now contemplating doing a carputer for my '98 4Runner. One of the members has done a very nice screen install that's got me salivating
    2001 Toyota 4Runner Rdiggidy's
    Well -- setbacks are sometimes just cleverly disguised opportunites: my car got broken into and the bastards stole my stereo and Riocar EMPEG which has been the staple of my car system for several years.
    As I'm considering carputering my vehicle, my first trade is going to be the laptop vs. motherboard setup. I've searched around and have seen that both are done (although laptops seem to be less common).
    My thought was to get a broken screen laptop off ebay. I was going to install under the seat (and get a battery that doesnt explode . Some things driving me that way are:
    - Seems the Laptop solution simplifies the power conversion problem. I can either use an inverter + ac adapter, or a single supply dc/dc converter. Shutdown would be done with the windows hibernate feature when running on batteries, and if the computer hangs, the worst case is that the local battery gets drained. I would need to build one of the common circuits outlined on the forum for powerup.
    - I do some amount of off-roading, so vibration is a concern. I thought having the laptop under the seat would provide some amount of shock isolation. Futhermore, notebook batteries are intrinsically less sensitive to vibrations.
    - Lastly, temperature extremes are a concern as I do a good amount of skiing and also live in a hot area. I would think the storage range would be -10F to 120F (i.e. when the car is parked and unused).
    I apologize if Im asking things that are posted already (there is a lot of info on the site).
    Thanks & Regards
    -Ted
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    my 2 cents
    (i have a laptop installed)
    first, i wouldnt worry too much about shock.
    also, the battery in the laptop has never served me any use.
    if you are truly worried about extreme temperatures, you want to look at booting from a CF card. this is an awesome thread about booting from solid state drives. although it's particular focus is on booting faster, it talks about how to set it up.
    Aug 2006
    Yep, you'd probably want to just take the battery out unless you plan on taking the laptop in and out, which I doubt since you are looking for a broken screen model.
    I've been researching the same question and want to point out that if you go the laptop route, shutdown is not really the problem, it is automatic startup. I believe some folks have figured out a way to do this by soldering connections onto the laptop motherboard, but otherwise, you are going to have to push the power button each time, which could be a pain if the laptop is not easily accessible. Again, you could relocate the power button, but that requires more soldering.
    FYI, I'm currently investigating a P3 or celeron solution as they seem to be cheaper alternatives to the mini-ITX; however, the decreased hardware costs may be offset by the need for a larger and more expensive PSU.
    Jan 2006
    Quote Originally Posted by Uther View Post
    Why would you want to take the battery out? Thats more or less the beauty of the laptop. Ive read other members and their mobos and they talk of 5-10 second boots(faster is likely possible) my laptop lives in standby and music is on instantly. Its beauty.
    Startup is rather easy, one member sells a complicated setup for doing this with many checks etc. Theres also another circuit on here(i use it) that is simply a relay and wires going to the power button on the front, you do have to get there.
    98 V6 Camry XLE
    Status-Everything is working again!
    No progress while I am in NYC
    Ze Worklog
    Aug 2005
    Thanks for the reply folks: There's definitely a lot more research for me to do. That was a good thread on booting from flash. Not sure if that's the path I'll go on, but reading about the "write filters" that inhibit writes to the physical disk would solve the shutdown problem and thus my need for a battery (which I was planning on using in lieu of a powerdown circuit).
    I will solder the on/off switch to somewhere on the dash.
    To power the laptop, I'm thinking of a simple DC/DC converter to the laptop DC voltage, or a power inverter. There seems to be ample information on inverters on the forum, but what i've noticed from experience what that the PSRR (power supply rejection ratio) kind of sucks on laptops. Most inverters output a 60 Hz square wave (as opposed to a sine wave) which induces all sorts of nasty harmonics on the input power. It seems these harmonics tend to couple through right to the audio output -- so when I had a laptop plugged into my car audio system, I could only play audio by removing the power cord. I'm sure that problem has been solved though and I just need some more research.
    Cheers
    -Ted
    Jan 2006
    DC-DC is the way to go, not only will it keep the audio noise free, its far more efficent. Plus they arent that expensive, I paid about 70 shipped for mine.
    98 V6 Camry XLE
    Ze Worklog
    Mar 2006
    Colorado, but Canadian!
    Yes, dc-dc all the way. Inverters seem to me kind of a half-*** job if there are other ways of doing it. Meaning if you are running some beast that not even the DSATX can handle, then inverter. You are not. So therefore, get a dc-dc.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2005
    Quote Originally Posted by 2k1Toaster View Post
    Thanks folks.. kinda what I suspected re: the power supply. However, that means I need to get a laptop that is less than 12V on the input to take advantage of a DC/DC.. right? I know some laptops are 13V and 16V DC input.
    Cheers
    -Ted
    Mar 2006
    Quote Originally Posted by Tedp View Post
    Cheers
    -Ted
    No there are units that take the 12v and turn it into anything from 6 to 24 depending on the product. Just like the igo thing that takes 12 and outputs between 16v and 22v depending on what you choose
    Constant Bitrate KaBoOoM's Avatar
    Oct 2005
    Portland, Oregon
    Uther, about your comment on the startup. If I go with a laptop I am going to have the power button routed to my ignition. When the ignition is turned to the point of starting the car it will press the power button. Don't know if it is a viable option for you or the original poster.
    I'm hungry
  1. fix a broken dell laptop?
    By kuo in forum Off Topic
    Last Post: 02-27-2006, 05:58 PM
  2. My laptop manufacturer employs a bunch of useless poons!!!
    By WoLLy in forum General Hardware Discussion
    Last Post: 02-27-2006, 02:23 AM
  3. Would it be safe to use my laptop?
    By Keyser in forum Newbie
    Last Post: 02-06-2005, 10:36 AM
  4. Replies: 1
    Last Post: 02-03-2005, 10:32 PM
  5. inverter + laptop problem
    By javii in forum Power Supplies
    Last Post: 01-07-2005, 03:00 PM
