Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Newbie Questions
  1. #11
    Aug 2006
    Awesome, thanks for clearing that up for me. I'm keeping watch on your worklog =)
  2. #12
    Aug 2006
    This might be one of the most newbie question ever..flame me if you want to, but I need to understand this.
    If i want to power my USB Hub from 5V wire running from PSU how do I actually connect this wire to the USB Hub..isnt the wire a bare 10awg wire for example..doesnt it need a small plug at the end of it so you can plug it into the USB Hub...or other Devices for example (my Creative Jukebox Zen for recharging which also takes 5V dunno how much amp it draws)
    Also can someone explain why some people ground the LCD screen and some dont...??
  3. #13
    Low Bitrate Shidoken's Avatar
    Jun 2006
    Hi MastaShake and welcome!
    Actually I was reading this and it's pretty much the same as the post that I've been going thru. I'm actually looking for a dist. block that's going to power my monitor and the cnx-p1900 psu. You can view the post called 'Noob confused about wiring'.
    As for the usb hub powering question, if you look at one of those carnetix diagrams, they say you could buy one from the mp3car store. (diagram is in the post too.)
    Well, keep at it. Cuz I will too!
  4. #14
    Elsewhere
    Quote Originally Posted by MastaShake View Post
    No, that would be "What do I need to put a PC in my car to play MP3s, videos and have GPS navigation?"
    For the USB hub, you don't need 10awg wire... The amount of current drawn byt the USB hub with all it's ports filled and powering devices isn't much at all, so a smaller wire is mroe than suitable.
    There has to be a ground to complete a circuit. That ground may be to the chassis or a line running back to the whatever is providing power to thge LCD.
    How about the Wiki?
  5. #15
    Aug 2006
    more questions
    hi..got more questions...as usual..
    Can someone please direct me in the right direction of making an on/off button in the dash..not how to make it in the dash, but how to make the actual button. Is it something you buy and then tap into the ignition wire?? or something like that.. i am a bit confused.
    thanks
  6. #16
    Aug 2006
    I finally figured out how to add rep to someone (didnt see that button before)..so I added some rep to you DarquePervert
  7. #17
    Elsewhere
    You need a switch that will maintain on/off state and put on the IGN line.
    It will act as a valet switch. If the switch is off, then no current will get to the IGN line fo the PSU or SDC, so it will not tell the PC to boot up.
    If the switch is in the off position whiel the car is running and you turn the switch on, the PC will boot up. If you turn it off, the PSU or SDC will go through its normal shutdown routine.
    Well, thanks.
    How is your project coming along?
    How about the Wiki?
  8. #18
    Aug 2006
    Thanks for you reply once again DP.
    As far as the switch is concerned, I search for keywords such as "switch", "button"...etc. Found some threads, now im going to google how to switch a wire..
    Well, like I said before I am going to do a fair amount of research before I even start buying anything. So I guess at this point I am.
    85% Learning
    10% Planning
    Once I start buying things, I will make a worklog..but thats not going to be for another couple of months or so.
  1. Newbie questions
    By peecee in forum Road Runner
    Last Post: 03-02-2006, 01:48 AM
  2. Newbie questions......sorry :-(
    By mikebailey_uk in forum Newbie
    Last Post: 02-19-2006, 12:33 PM
  3. Replies: 3
    Last Post: 12-02-2005, 12:33 PM
  4. Newbie Questions for a 2nd Time!
    By Sound of Silenc in forum Newbie
    Last Post: 03-10-2005, 04:37 PM
  5. Newbie here. Introduction and some questions...
    By 3Point4Tacoma in forum Newbie
    Last Post: 07-22-2004, 01:41 AM
