Results 1 to 10 of 11
Thread: Nissan Versa
    May 2005
    Nissan Versa
    So i got one of the new Nissan Versas and i am trying to find a spot for the LCD, I do not want to take out the stock radio, any ideas?
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    What's the little cubby right above the radio? I have an altima and I know there's some similar space behind my dash (no cool cubby in mine ) and it wouldn't be deep enough, but if yours is you could put a flip up screen here, otherwise I'd say right above the cupholders somehow.
    May 2005
    The depth of that cubby hole is about the size of a cd case. I was thinking that i could put a fold out there, but it might not be big enough.
    Aug 2004
    That sounds about as big as mine would be if there was an actual slot in the dash, but there's no real way to tell until you take it apart.
    May 2005
    yeah i figured that. Little scared, only had the car for 16 days.
    Sep 2006
    Quote Originally Posted by landonb16 View Post
    This should be its sister model the Renault Megane
    May 2005
    sister?
    Mine looks like the 1920 T model compared to this...
    Three options, really:
    - Get a single-din slideout unit from digitalww.com and put it in the cubby above the radio
    - Get a single-din aftermarket headunit, put it in the cubby above the radio. Put the 7" LCD in the dash where the two-din radio is now.
    - Sacrifice the cupholder area and fabricate the LCD into that section of the console.
    I'd go with the first option for two reasons:
    - If that is a single DIN up there, it makes for an easy install.
    - It makes it easy to put back to "normal" when you are finished with the car.
    - It's not readily apparent that an LCD is in your car. You can tuck it away and it's hard to see what that is. Double bonus if you can keep the cubby cover in tact.
    If you're adventurous, you could go with option 2. Would look the most stock, but would require not using your factory headunit.
    Option 3 is really valid only if you like fabricating and don't care about returning the car to stock form before reselling it.
    My $.02
    Ok, super bonus option:
    - Relocate the AC controls to the cupholder area, and fabricate the LCD into the space where the AC controls were.
    Nov 2006
    I like to add a Legacy LDNTV65U unit to my Versa. Would a standard double din reciever replace the stock unit?
    Here's a pic of the Legacy.
  1. Carputer for 2005 Nissan Altima
    By checksum in forum Newbie
    Last Post: 03-24-2006, 01:08 PM
  2. Nissan skin
    By djR1SpecV in forum General MP3Car Discussion
    Last Post: 01-11-2006, 10:25 AM
  3. new nissan software?
    By dim-8 in forum Software & Software Development
    Last Post: 02-15-2005, 07:19 PM
  4. Nissan Xterra XPuter Stage 1
    By OKC-X in forum Show off your project
    Last Post: 04-02-2003, 11:00 AM
