Results 1 to 8 of 8
Thread: 2000 jeep cherokee problem
    Sep 2006
    i just got a 2000 jeep cherokee and have had a subwoofer, an amp, and a deck waitin for it.....i installled my deck fine but when i came to run the monster cable from my battery to my amp i couldnt find anywhere to run it through...if someone knows anything about this id sure appretiate it
    ps i really dont wanna drill any holes
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    if theres no where to run it, and u dont wanna drill
    then your stuck, why dont you want to drill? its not hard
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i did not drill and i passed a cable in my citroen xsara.. i passed it allong the engine then to the passenger door (inside the body).then i made a hole in one of the protective rubbers..then into the dash then under the carpet...
    i will try to post pics for you.. the cable is only seen when you open the door (a small portion of it) in the door hinge area.. i prefered that than to drill any break pipes
    Sep 2006
    well if i were to drill where would i want to?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    There has got to be some way to get your cable through. You need to find a rubber boot that covers something else going between the passenger compartment and the engine. Make sure it doesn't get hot, or that there isn't a lot of movement, and then, using a razor blade, carefully slice an opening in the rubber boot, and slip your wires through.
    I have worked on many different cars, and never was I unable to locate a place to get the wire through. It may not be easy to find, but there is a place. I don't think I EVER had to drill a hole.
    Michael
    Aug 2006
    Spring City, Tennessee
    look for the boot that contains all the wiring going to the dask and in car fuse box. Usually there is enough free earea to at least slip a 4awg wire in through that. Only issue with this location is it may or may not be on the opposite side of where the better connections are, so if your using a kit, the wire included may be a tad too short if its on the opposite end.
    If you HAVE to end up drilling, Look for a convenient spot on the inside of the car under the dash where you'd want the wire to come out of, and then find that spot in the engine bay of the car. Make sure nothing is in the way in the engine bay, and when you srill make sure to take it slow so you don't end up shoving the bit through the firewall at the end of the drill through and puncturing something in the car.
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    k, i should've added this to my post
    no matter where you put the wires through, it its going through any metal make sure you have a rubber grommet, wouldnt want to have the cable cut
    by car flex, expansion/contraction of anything, besides, grommets are like 50 cents, better safe than sorry
    Sep 2006
    thanks for all the help butit look like i will drill...ive found a place wher it looks like it is ok to drill....when i tap on this place,near the front driver wheel, it sounds like plastic...i got a gromet that fits nicely.
    i hooked it all up and come to find out my subwoofer is defective so i have ti send it back so it looks like ill be waitin even longer....
  1. 2000 Jeep Cherokee carputer install - worklog
    By akula169 in forum Show off your project
    Last Post: 12-13-2006, 02:33 PM
  2. 98 Jeep Cherokee Audio Problems!!! Please Help!
    By maxcarpro in forum Car Audio
    Last Post: 09-28-2006, 02:04 PM
  3. 97 Jeep Cherokee stereo help
    By Bigmanbrainy in forum General Hardware Discussion
    Last Post: 11-04-2005, 03:50 AM
  4. Jeep Cherokee Screen location
    By The Knot in forum LCD/Display
    Last Post: 09-03-2002, 11:27 PM
  5. Jeep Cherokee
    By mnbujold in forum Off Topic
    Last Post: 03-07-2002, 07:17 PM
